High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
Chuck252
Thanks guys. That is one big alternator.  :o
I've been trying to understand some of the electronics involved in this, and I hear Stan talking about an amp consuming device. How do you restrict amps in a circuit?
This video makes good inspiration.
Looking forward to your videos IornHead.
IronHead
Driven by an AC motor so size is mostly the big AC motor driver.
popeye68
If i heard it correctly he said ;
"applying 5volts and 2amps to the field of the alternator"
and
"we use the alternator as a amp restrictor and alow the voltage to take over"
WOW
keithturtle
Popeye, that's what a resonant RLC  [resistance, inductance, capacitance] circuit will do for ya, get the voltage high and keep the amps low.   But I ain't done it yet, on any scale.
(edit: not resistance, but "resonant")
Y'all might have seen these
http://www.ngsir.netfirms.com/englishhtm/RLC.htm
http://video.google.com/videoplay?docid=8101761120710333337&q=resonance+MIT&total=44&start=0&num=10&so=1&type=search&plindex=1
That MIT class is long, but I found it worth it,
and both give a good understanding of the tank circuit principle.
Turtle
Soli Deo Gloria
gotoluc
Hi Guys and IH,
did some more tests at 24v, 36v and 110v, in a smaller container ;). This cell design work best at high voltage but heat happens fast as it goes up. Also less and less of KOH is needed as voltage goes up, a minute amount was needed at 110v.
I wrote the voltage of each pic below and the video is at 110 volts and with next to nothing of KOH, I drop it till I could run the cell for about 3 min. without overheating.
Luc
