High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
ZeroFossilFuel
Quote from: dlwammo on July 26, 2007, 06:19:49 AM
@ZFF
Have you tried to "rough up" the plates on both sides with vertical scratches
or do they still have the brushed finish on them?
Dan
If you've been following my brief video series you'd know. They are deeply and well sanded vertical with 36 grit.
My public PGP key. Please help support my work. Donate by PayPal
hkyle
@zff
Check to see if you have even resistance between the cells. It's a pretty good build so it should be quite even. If not dump that baking soda stuff and try again. I don't like using baking soda, go down to the old grocery store and pick up some lye. Well if they sell it in your area anymore.
The reason why you have small bubbles on the outside and bigger ones in the middle is because of the field you are creating..surface tention..resistance in you cell. You have a stronger field on the outsides and a weaker one in the middle. The more voltage to have on the cell the greater the field will be. Think about it....voltage...metal plates....equals.........
Also how did you add the soda to the cell?
Quote from: ZeroFossilFuel on July 26, 2007, 10:34:32 AM
@ZFF
Dan
It?s easier to be forgiven than it is to get permission....
hkyle
Put the neg on the volt meter onto the Neg middle electrode. Take the Positive starting at the far end and touch and record each voltage from the outside in....
what are the results?
umm not this way.....
0/1 = 3.6v
1/2 = 3.8v
2/3 = 3.9v
3/4 = 4.2v
4/5 = 4.6v
5/6 = 5.5v
6/7 = 6.3v
7/8 = 8.5v
8/9 = 8.0v
This way Left row pos / right row neg....
1/1 should be 48v
1/2 =
1/3 =
1/4 =
1/5 =
1/6 =
1/7 =
1/8 =
1/9 =
ZeroFossilFuel
I will look for lye but I'm making no promises,
re: voltages, just add. They add up to 48 which is what I put in. Since they divide across the cells at all, albeit unevenly, there is resistance. Simple series resistance circuit.
All I did to add the baking soda was take off power, stir it into the electrolyte tank outside the plate cavity, swish it around good to let it wash into the plate cavity and reapply voltage.
Also tried connecting it to my intake manifold vacuum this morning. That was almost a big mistake. The long sides of the tank buckled inward. My top cover needs a ridge of acrylic that centers it to the tank like a cookie jar lid before I tyr that again.  :-\
rapttor
ZFF, if you have it sealed up that good, you might consider a bleed off valve, that you can just crack open to allow a minute amount of outside air in, so it doesn't fracture your cell housing. another option, build it out of heavier acrylic... like 3/8".
just babbling...
-rapttor
Successfully Perpetually Failing at everything I do...
