Plasma Electrolysis by IronHead
Started by IronHead, March 08, 2007, 06:31:51 PM
Moab
Quote from: Robb077 on July 02, 2007, 10:20:47 AM
How to choke the RF for non-electricians ;D
The SS tubeing is the housing around the cell. It takes the place of the jar in the testing phase. water flows through this cell to a heat exchanger in a bigger tank. Yes Robb0 you are correct. The RF is from the spark (Plasma) It will mess with TV's and radios. ;) Moab.
PS Nice chickin
Robb077
Moab:
Still confused  Are you saying the "tubing" is now the vessel for the plasma? what is the diameter? What is the bottom made of?
What tubing are you using to pump the water?
hkyle
hey guys does it need to be a stainless steel screen for the + side or can it be a ss plate or a pipe. I was at the farm this weekend and picked up a slick unit that will allow me to slide the Rod in / out without opening up the cell. Seems to work for that purpose but was thinking about the screen. Over at JLNlabs they don't have a screen surrounding the tungsten rod and it seemed to work. I was also thinking that maybe I could use a SS tube for the + side and have the rod in the middle of that, so the Tube would be replacing the screen and having the water flow right past or through the plasma.
what do you guys think?
I will post a pic when I get a chance.
kyle
It?s easier to be forgiven than it is to get permission....
Robb077
Ironhead:
Since you helped Moab build his, maybe you can explain what the ss tubing is used for. Maybe a rendering would clear it up easily. ;D
Is Moab using a vessel made of ss or just the pipes to carry off the water to the pump? Sounds like he is not using glass.
Robb077
Moab:
Maybe you have a big coil of stainless steel tubing around the plasma inside a 50 gallon fiberglass tank. Is this the setup?
