new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
FredWalter
Quote from: magnacoaster on March 09, 2007, 01:37:35 AM
total power intake 1 amp @12 volts
total output  20 amps @ 12 volts
One can never have too many multimeters. This week Canadian Tire has them on sale for $20, if you want to pick up a few more so you monitor the voltage/amperage in more places when you are testing your device.
wattsup
I've been doing some great testing along these lines for quite some time now.
If the battery is reading 14. something volts, you're alternator is not producing 20 amps since the regulator will only put a light riding current on the exciter coil. So your prime mover can turn at 4000 rpm if I am not mistaken.  But I did not see anything running at 4000 rpm. At best, what I saw from the video is around 240 rpm and that will not produce anything with the alternator.
Plus once you put a load on the battery, hence on the alternator, like if you put a battery having only 11.5 volts, the alternator will almost seize. A 63 amp alternator at 20 amps has quite a strong drag factor that your prime mover will never be able to move in the way you have your system.
Sorry but I don't buy this at all.
Craigy
I agree with watts up, everything shown is so badly presented it does not inspire confidence.
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
pese
http://www.youtube.com/watch?v=sJXsg7bvCLU
This here must possible THE RIGHT VIDEO to the
maschine that was shown in beginnig this thread...
but .....
Pese
http://ch.to/FE   here some news now-
magnacoaster
like everyone out there i to have to learn about things !
if you find it easy to say that it does not work then you can build your own
i am doing the best as this is 2 years of my life into this so far !
also everything you have learned will not work as all the ideas about gears and pulleys
are not right as we wanted to go faster and we had a 12 tooth  and 35 tooth we swaped  the 12 to a 16 only to see it go slower !
i also want to get all the bugs out before i change it over to a Electronic control as this will make the change over easy as well as not cost me a few hundred everytime we burn out a controller !
i have melted coils here as well as parts that looked good on paper only to find in the real world that there was no way to make them work !
as well i plan to build a new type of gen in the next few weeks to get more power and less pain out of it the same one as the wind guys have that needs to go 100 rpm
that way i can gear it to run and have almost no load on it
our speed right now is not right i have ordered a new sprocket but i cant get it till monday as it was not in stock !
if you want to go and buy all the crap i have bought in the last 2 years you may want to have a deep pocket as i have put in 120,000 in time as well as 10,000 in cost that came from my pocket as well as all the nights that i could not sleep !
the little units you see on here for display will not work the same as the next size up if you start with a 10 mm magnet and go and increase it to 1 inch magnet you will see what i mean !
i never said i have a phd in electronics or in machanics but what i do have is the chance to make a difference and to make my unit work !
maybe if we all work togeather then the world would had green power by now  !
Richard
