new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
Ergo
I'll contact him and hopefully he's got the time to come see your "device" and also
take measurements of his own without interference from your staff.
Is that OK with you?
Quote from: magnacoaster on February 17, 2008, 10:14:55 AM
what the university was just not enough ?
tell him to send me a email he can come to the anouncment and see it as well
there will be people there who will have all the test equipment hooked up
oh but that will not be ok cause you want to have it all your way  ?
grow up and see the light (no pun intended)
Richard
Ergo
He's been contaced.
I dare you not to turn him down.
Let him freely perform any measurements neccesary.
Groundloop
Quote from: magnacoaster on February 17, 2008, 01:24:48 AM
ok check out the web site www.magnacoaster.com  prices there now
for the people who need more   www.youtube.com/magnacoastermotors
yes we are patent pending in the USA now.
Welcome to my world is it time for a change yet ?
Notice on my site the letter from Arnold S.?
Richard
Richard,
I've just finishes reading this thread and also the information provided on your web site.
I'm all in for the free market idea and I can't see any problems with a firm earning money,
but the prize tag on your typical unit for home usage is way too high for the average family.
As stated on you web site you estimate a 10 year life span on the system. If we take the
initial cost of you system and add the cost of 10 batteries and 2 x 10KW/h inverters for
powering a home then the cost of all this makes it so high that the savings to be off the
grid for 10 years is non existent. In addition to this is also the life span for batteries.
Normally one should expect to change batteries every 10 - 15 years.
Is there any plans to further develop your system to run without batteries powering
an inverter (or two) direct? Also, du you have plans for mass producing units for home
usage so the the prize tag will be low enough so that a typical family can afford to
buy you system?
I think that most people will not buy a system that takes 30 - 40 years of usage before
any real savings can be done.
Groundloop.
hartiberlin
Richard
Hi Richard,
many thanks for posting the new video.
Looks pretty good, if your dead 12 Volt battery can now
power almost 550 Watts of load and also powering
the drive motor...
Well done.
So I guess you just drive your magnet rotor much faster
with the drive motor and the gear and just use the right airgap
to not drag down the magnet rotor too much ?
Probably here your idea is the speed the rotor induces
voltage into the pickup coil sitting ontop your magnet rotor ?
As the higher the speed is, the higher is also the induction voltage and the
power output of the coil, although the coil looks pretty small...
So now with your new box unit you say on your web page
you have a solid state design in an oil bath ?
Have you found a way to energize your magnets with
just a solid state driver and use just also a solid state pickup
coil above it ?
So no rotating magnets unit anymore ?
Looks good, if there is really only solid state parts.
Maybe you can also post a video of this new unit again with
starting with a dead battery ?
You say, that you use now as input 12 Volts at 60 Hz,
so do you need a converter from your 12 Volts battery to
supply the 60Hz AC ?
And you say you get 5 to 10 Mhz frequency out from your
coil and that this must be converted to run the battery charger or
inverter ?
So will these converters also come with your box ?
Yes,I also thinkyour devices are a bit expensive.
So maybe you could just try to build a smaller one
for maybe constant 300 Watts output for around 500 to 1000 US$.
As you would not need all the time the 300 Watts in your household
but insomehours much more,e,g, if you cook or take a shower,
the constant 300 Watts could charge up a battery bank, so that you later
could draw from the batteries also  for instance 5 to 10  KWatts peak power
for some short time, if you need to cook or heat water for instance..
Anyway, interesting to see Schwarzenegger respond to your
email, but it looked like a standardanswer and not related to
your invention.
Good luck with all the business setup and please keep
us posted about your progress.
Regards, Stefan.
magnacoaster
no the motor was the gen on that unit it all came from the one place
no i used the voltage injected into the coil to multiply the voltage and the amperage
the coil is small there is no need to have miles of wire as its just a waiste
yes we use the oil to cool the coil.
coil above it ?
magnets are rare earth no need to energize them at all
there is no reason to move anything as you can make power with no movment
only thing that moves is the oil pump
unit on the bench needs the regulator put on as we keep boiling the battery
i have the parts will make it this week
no the timing device will keep the freq. stable.
inverter ?
no it can go right into the battery it will make the battery last longer
as it does not have the heat buildup
we are going to have a deal with a inverter and battery man. these will be a kit
avaliable local in north america
its $2 a watt and it does not need acres like solar
your invention.
we sent him a invetation to visit our plant and be there when we anounce the plant opening in the fall
of this year.
we are also working on a refit kit for autos no plug in think it will be big ?
Regards, Stefan.
