new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
Frederic2k1
Hahahhahaa... It is nothing more than a clever switching on and off of the little coil at the right moment. And to prevent that the backEMF of the coil brakes the spin wheel, he has very long distances between the neodym magnets.... ( ~ 60 ? between them)
So lenz law is not broken, he is only going around it.
Very clever. Respect.
Am I violating against any board rules if I make a circuit diagram public ?
hartiberlin
@Frederic2k1
go ahead, if you think you have found the answer
how he did it.
Yes,it seems to be that Richard has found a way to
use the Lenz law in a usefull way instead of breaking or dragging down the
rotation.
I am already very cuious,how he can do it now in his new
device without any motion at all only with solid state parts..
Seems he has found a way to tap the magnetic field power
from permanent magnets
with very low input power and delivering much higher
electrical output power.
Regards, Stefan.
Frederic2k1
ok Stefan,
I will go ahead ;)
Attachted are two pictures.
The pictures are self-explaining.
QuoteI am already very cuious,how he can do it now in his new
Yes, I'm too. ;)
And here the possible-circuit diagram:
kind regards
Hendrik
hartiberlin
Hi Frederic2k1,
yes, you are right,
I think this is the circuit diagram.
But as Richard said,
he might not have a motor to run the rotor,
but the black magnet rotor is just only pushed by the electromagnet itsself !
So you can forget the motor.
It seems not to be needed.
It seems he is generating all the output power from the BackEMF
of his coil being switched off at the right iming point and
the stacked magnets on the core seem to help
push then some more induction through it,
so the BackEMF energy output pulse must be very high
and thus it returns more power to the battery than it is drawing
from it.
It probably depends very much of all the timing and spacing
of the magnets and of the right coil parameters,
what Richard have also already told us in earlier postings,
as he said, he just got the coil wire size and dimensions right now
and other dimensions andwire sized would not work.
So this effect can only be got by finetuning all the components
and choosing the right dimension and distances of the elctromagnet,
magnets and RPM speeds and point contact materials, etc...
At least it is really an amazing video, seeing him to draw about 500 Watts
contineously from a dead car battery !
Well done Richard !
Regards, Stefan.
hartiberlin
P.S: I wonder, if it wouldn?t be better to have a very fast diode graetz
bridge for the BackEMF pulses to recharge the battery...
But as these Back EMF pulses  are mainly flowing into the direction of the
battery it is a negative current, so the current direction is back into the battery
as I have seen, when I experimented with my Newman coils
as you can see for instance here:
http://overunity.com/newman/spike2.JPG
There is shown the input current from the power supply into a Newman coil.
As you can see, the current is negative in this big negative going spike
( The scope groundline is in the screen center)
Regards, Stefan.
