new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
powercat
ramset
Richard  its nice to see you have the heat on in the lab great stuff on core  on core   Chet
Thanks Grandma
bolt
Richard your video would be slightly more impressive to show that when the battery was unhooked the lights went out. Also disconnecting the inverter to show the power is really going though that too and finally by including a couple of meters here and there so we can see charge current voltages on the circuit. All we can see right now is a box on the table with a car battery and 11 lamps that it probably connected to the the grid. You need to show where ever possible that is NOT the case.
A good final show of power would be to slow down your generator by hand so show loss of power and the lights dimming. This will help diminish claims that the box of tricks is simply hooked up to grid power.
If you need guidance on better demonstrations of power then look at Steven Mark TPU vids where he goes out of his way to try and convince everyone there is no trickery involved. Thats means a good camera pan around for secret wires, connecting up the various components and inclusion of meters so we can see the amps and volts produced.
Finally no one will bite the bullet till you get this independently tested and verified.
In case im wrong then well done!
ramset
Bolt I could be Mistaken but I believe  his device made the transition from mechanical to solid state some time ago    Chet        Richard do the green show  in Toronto
Thanks Grandma
bigred
Richard,
a good man once said, no matter what you show them there will always be critics. and the closer you are to completing the dream the more the dogs (critics) will bark. Keep the good race going. never mind the critics. im sure your not the first inventor that pple questioned. i know your on the right pathway keep on going forward
