new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
Bobmar
Try it with electric water heater or kettle that will prove there is real power coming out of the machine the convertion of electric to heat is almost 1to1 showing the machine under constant load all the time
that would impress even the most skeptical.
ramset
Thanks Grandma
FunkyJive
Skeptic_tc wrote:
QuoteMy fervent hope is for us to somehow tap into an inexhaustible supply of energy such as gravity, solar, geothermal, Earth's magnetic field, etc.  There is where our 'free energy' has always been and hopefully someday where it will come from.
Hi Skeptic.
I am conducting experiments and tests in levitation and propulsion, and have very good reason to believe that free energy may be derived from Zero-Point Energy (due to commercial sensitivity I apologise in advance for not being able to reveal specific information), not the conventional forms that most would currently understand and appreciate.
In short, you can change the energy state of electrons to create what are known as "photons" (such as forcing a current through a tungsten filament), but force a diversion in the natural free path of an energised electron as-well and something very interesting happens - which I believe bears relationship to ZPE. Gravity, themal, solar, magnetic (etc) would actually become the tangible effects of ZPE that we can all see and appreciate.
EHT pulses through an electrolyte for example could achieve this at atomic level, resulting in observable resonance as ZPE attempts to regain entropy. You therefore have to support this resonance and not dampen it (typically somewhere between 1 and 6MHz for a lead-acid battery).
Richard - First, kudos to you sir for the time and effort that you have expended on your device, and the apparently positive results in your video footage (you could do with a better camera-man though  ;D). However, though I may be wrong (please excuse me if I haven't studied the entire thread), I would suspect that you may need the lead-acid battery to effectively self-charge from a cyclic resonance observable across the terminals during each charging cycle, whereas a regular capacitor may not lend itself nearly as well. I would be interested to know whether you have had to tune your device with applied capacitance to resonate with your charging coils, or change your coil inductance(s) to resonate with the battery?
On a side-note (again, please excuse me if already covered elsewhere in this thread), I saw the use of inverters in the original video, though as they are electronic devices they would have a brown-out (low-voltage drop-out) dropout level, so not the best demonstration of linear charge and discharge.
Nevertheless, as I say, I have seen enough myself to believe that over-unity is entirely possible and, after you've been at the game of new science long enough, certain patterns emerge which puts your level of understanding considerably beyond traditional science - though you'll probably have discovered this yourself already   ;)
My very best wishes - and good luck !
FunkyJive
"Invention has its value, but discovery is priceless"
"Faith from the wealth of negative speculation cannot deny faith from the sparks of promising experimentation"
"A quest of impossible odds is not driven by expectations of what is achievable, but by the certainty of what is not"
"It is not weak minds that perpetrate misconceptions, but strong minds heading in the wrong direction"
"Experimenters seek understanding from achievement, academics seek achievement from understanding, whilst sceptics would seek to deny them both"
"Once the world was flat lest we should fall off. Once man could not fly as he was much heavier than air. And so we arrive at another threshold"
BD Townsend
skeptic_tc
Hi Funky,
I've read a bit about ZPE but cannot make sense of it from my admittedly layman's perspective of the physical world.Ã,  I understand your comment about electrons jumping from their 'normal' energy level to an energized state and the subsequent realease of a photon of an equivalent amount of energy when it drops back to it's normal 'rest' state from my high school physics classes.Ã,  What I don't understand is how you take an 'energized electron' and force it somewhere else and how that might make more energy than was used to make it energized in the first place.
I have seen quite a few videos of devices claiming to have more energy out than in and have problems with each of them for different reasons depending on how they went about 'proving' their claims.Ã,  The fundamental problem I have with all of them, though, is that they violate the second law of thermodynamics - although some claim that they do not create energy and instead tap into an existing energy field and focus it to do work for us.Ã,  That is certainly a plausible explanation of 'free energy' but I have yet to see a device that actually does that except for solar panels that convert photons of particular frequencies (usually in the visual portion of the EM spectrum) into electron flow.
I will learn more about ZPE simply because I do not know everything and want to learn more.Ã,  As a firm believer in the established methodologies of the scientific community, though, if any of these devices were truly possible I believe they would have been reproduced by now (I do not subscribe to the big company conspiracy theories because there is plenty of money to be made using devices such as these.)Ã,  Until I see device I can use I will continue to be as skeptical to the claims of 'free energy' as people were in the olden days to snake oil and elixer salemen.
Obviously I am a minority in this forum and no one likes people who rain on their parade.Ã,  I encourage everyone to consider me a source of inspiration and strive to prove me wrong.Ã,  I would absolutely LOVE someone to do it.Ã,  There are a lot of problems in this world that 'free energy' could help solve.
And I reiterate, I will happily test anyone's device at a facility of their choosing if they truly want a skeptical eye to make sure it is operating as they think it is.Ã,  That is after all how peer reviewed science works.
And secondly reiterating, I would be ecstatic to admit my error on TV, YouTube, here - ANYWHERE.
TC
FunkyJive
Hi TC.
First, make no mistake that we're all learning about the world around us, and like yourself I don't profess to have all the answers - merely that my observations to-date have reinforced personal beliefs that are necessary to prove to yourself. It is most important above all else to remain not necessarily sceptical, merely open-minded so as not to inhibit hitherto unrealised possibilities.
OK, just a little backgrounder (as I and others understand it)...
ZPE is an all-pervading force that all matter in the known universe is subject to (just for purposes of explanation let's call it a "field"). We all live in it, but we can't quantify it by traditional means as we have no point of reference by which to measure differentials against this all-encompassing force which endeavours to sustain entropy. We may well see its effects though, and then hypothesise over its existence to explain tangible effects that we can observe.
However, a medium it most certainly is, such as when photons travel through space. Ever wondered what a magnetic field actually is, or what a photon is, despite having taken advantage of its effects the world over? Well, I would suggest that a photon is not a particle or a wave (despite evidently possessing both properties), but is something akin to a rotating smoke ring that travels through the air. However, in the case of a photon, it is the Zero-Energy field that conveys its energy from one tangible point to the next, and an electron transferring to its low-energy state is the ZPE field accepting the transfer of energy (i.e. recovering entropy in the energised particle). This then creates a wave disturbance in the ZPE field (i.e. the energy is distributed away), so that energy can be conveyed from one physical form to the next (for example, a lamp energising a photo-voltaic cell), and the very reason why photons appear from "nowhere".
Magnetic fields are actually a polarised, rotational property of ZPE, where we experience resultant forces which transcend non-metallic solids (aka "insulators"), whereas the property of metals (readily releasing orbital electrons to ineract with the influence of the rotational field) can develop either flux concentration or an electrical current with relative movement between the conductor and the field (otherwise all charges remain in balance).
However, there is one particular property that is rarely appreciated in the physical, tangible world, and that is of time itself. Work done equates energy with time, but change time itself and things become rather different  ;)  Now if you create a disturbance in the ZPE field, then you are creating a distortion in relative time - affecting all matter that is subject to the ZPE field. This is where relativity plays its part.
For example, imagine a time "bubble" if you will, and you throw a ball through this bubble, to emerge from the other side. Now if the time bubble is exerting a significant forward shift in time, then the ball would first travel towards the bubble at a given speed, go through the bubble at a much greater speed (from an external observer's viewpoint  ;) ), and then emerge from the other side at the same speed as when it entered. Traditional formulae would therefore suggest an input of additional energy to speed it up through the time bubble (i.e. to get from A to B more quickly), where in actual fact it is time-shift that gives rise to this effect.
Consider also "Intertia". So obvious isn't it - you try to push a large heavy object along but it doesn't want to move. Now consider ZPE and you'll be on the way to understanding inertia and what it actually is. Then you have gravity - yet another physical effect of ZPE - realised in a different way.
Perhaps I should stop there, but maybe something for you to think about. The trick however is understanding how to actually yield a shift in the time domain by influencing ZPE and, unlike trying to overcome inertia with conventional thrust, this is the secret to propelling a mass at the speed of light  ;)
All the best,
FunkyJive
BD Townsend
