new magnetic motor goes 2000 rpm without load 1000 rpm with load
Started by magnacoaster, March 09, 2007, 01:37:35 AM
magnacoaster
hartiberlin
Hi magnacoaster,
so it seems you are just using one battery only ?
So does the 5 amps flow out of the battery or back into the battery ?
magnacoaster
we have the battery charged its taking 2 amps continus
the 5 amps we pulled was on the pump
MeggerMan
Hi MC,
Bit confusing the "pulling" and "taking", no indication of direction?
Can you put it in simple terms i.e.
Battery supply: 12Volts -2.0Amps (charging although the meter shows this as +2amps).
External load: water pump running at 12Volts +5.0 Amps
Rob
magnacoaster
Battery supply:
12Volts -2.0Amps (charging although the meter shows this as +2amps).+
External load:
air pump running at 12Volts +5.0 Amps
