Easy Bedini
Started by Limoman7, May 05, 2005, 01:21:30 PM
Limoman7
I'm very interested in building a Bedini type machine. My problem is time,tools and money.
I don't have a lathe in my garage, I have a day job and can only afford to spend about $500 on this.
Here is my plan of attack, please let me know if I can get results from this.
2-electric scooter motors 250 watts each from ebay
4-12v scooter batts
1- 20lb flywheel
1-auto windshield washer switch; to cycle drive motor off/on
1-bicycle hub; one way drive
2-capacitors: start and run caps
1-Large vacuum tube; instead of a transitor
1- power conveter DC/AC
2-battery tenders; smart chargers
1-solenoid
Ok so those are the parts....
My thinking is that by using the one way drive on the drive motor there will be less drag on the flywheel
when the motor is off. Using the large Vacuum tube instead of a transistor will solve the over heating problem.
The start and run capacitors from an old air conditioner should work well to get the flywheel up to speed.
Using the smart chargers to keep the pair of batts fully but not overly charged will help them last longer.
I can use the infinte adjustable wind shield washer switch to cycle the drive motor off and on just right.
Using a solenoid to flip from one pair of batts to the other each time the drive motor cycles on so as not
to drain the batts too much will limit the drag on the flywheel from the generator.
Well there it is, if you have any suggestions please chime in.
oouthere
I highly suggest you read his booklet first as you need to understand what he's doing.? I know you can't use a simple switch to energize and de-energize the motor for the pulsing.? It has to be either mechanical timed or electronically triggered, but it would be impossible to use a hand switch.
http://www.amazon.com/exec/obidos/tg/detail/-/091411901X/qid=1115821282/sr=1-1/ref=sr_1_1/102-1309227-4117700?v=glance&s=books
The motors he uses for his high effeciency experiments are brushless, stepper type motors.? One in particular was only 12 watts and achieved about 800% o/u according to what I've read.? I'd go to ebay and find a brushless motor, sometimes you can pick-up one fairly cheap ($40) that needs no special driver and is variable speed by adjusting the input voltage.?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=71400&item=7512880184&rd=1&ssPageName=WDVW
The above motor is what I've bought, very high quality but do not place two 12v batteries in series as 24.1vdc is too high and it will burn-up.? The input shaft and bearings are almost frictionless and can handle a great deal of side and forward torque with little power loss.? Under a good load she will use about 2 amps so figure 48 watts.? You may also not need a flywheel as the outside spins and does have a smoothing effect on pulsing.
I need to start on my next Bedini project also, just having too much fun with dirt bikes and boats!
Rich
Limoman7
Rich thanks for your reply.
Yes I think you're right, I'll read his booklet before I go ahead a build one.
Oh,.. and the switch I was thinking of using is automatic. I't's a windshield switch just
like in your car.
I'm also into dirt bikes. I race vintage dirtbikes in AHRMA.
This season I'm racing a  '72 250 Bultaco Pursang and I'm in the process of building a
'75 Kawasaki  KX250 for next season.
Glen
mythtek
Hi guys,
I'm thinking of building a bedini motor. I have no idea where to start, but I am skilled in electronics and have an electronic engineering background. The thought of developing power sources that can not only sustain themselves but put out more power, sounds too good to be true. I have seen most of the videos and spent the last week reading most links on the internet regarding overunity engines
Is there a book or plan/formular to start with that can generate more than unity.
I have a mates who are quite wealthy and skilled in production/electronics also and if given the advice to kick this off, can between us build anything described. However,  without definite plans to start with, I feel loath to proceed.
Over unity is such a great concept. I believe in it, but have no idea where to start. Guys, Please don't dis me over my ignorance.
I need advice on how to start and need some real circuits and inexpensive designs to start with to prove that overunity is real to my friend who I'm sure will finance some extravagant experiments with me - the plans and results of which we will freely share.
Free energy means not only free from the government and universe, but free to world knowledge.
If anyone can asist me please send responses to mytrek@iprimus.com.au
gezgin
I want to build bedini motor-generator ,but making bifiliar coils are problem for me.
There are some information this site and yahoo SSG grups.
http://peswiki.com/index.php/Directory:Bedini_SG:Self-Runner
I have seen miracles happen to men and women in all walks of life all over the world. Miracles will happen to you, too?when you begin using the magic power of your subconscious mind -Joseph Murphy
