Thanks to ALL for your help!!
internal combubtion engine to run on compressed air
Started by innovation_station, March 28, 2007, 10:25:15 AM
innovation_station
agin i did this many many years ago
in fact i built this in high school
it will run on 30 lbs of air
it agin is simple
no oil no heat just air
it worked verry well too
i have left this alone for a long time but if you want to build it i can tell you how
simply take a 4 stroke lawn mower engine
and do 1 thing to it
take the cam shaft out have some one weld 2 more lobes on it so the cam i dubble lobed
put it back togather
put the piston a tdc and drive air in the spark plug hole and  pesureize the crank case
bascily all you are doing is moving the air around
with the cam being dubble lobed it allowes the valves to open and close on every up and stroke of the piston
agin verry simple the only problem i had at the time i built this was to control the input air
so i just blew it in all the time
ran great and for lubrication put oil just a little in with the air
not much more to come on this
i had an engine that was finished
but have moved so many times since then and it has become lost agin not hard to build
is
Low-Q
With compressed air as fuel, you're again limited by the laws of physics. When pulling out too much energy, the decompressed air will cool down quite quick, and left there is no pressure to run the engine. And you are depended on external heat to make it run further. Before that you must use plenty of energy to compress the air. One important thing to consider when having plans for a free energy device is o look at the energy required to make it. How much will this process damage rivers,  and the air with pollution?
Solar energy is a source of energy, which source is the reason why everything else on this planet is running. Why take a roundabout way, when you have limitless of energy, free, from the sun itself?
Br.
Vidar
innovation_station
i built this peticular engine when i was 15 years old i am now dubble that and i have done nothing more with it just thought that i would post it to show that it could be done easly
is
Draco Rylos
@Low-Q
Ease up on the man, I had an idea similar to that back when I was a about the same age up until I was about 18 or so. I didn't think about how to control the air going into the cylinder at the time though. To me it was a wild idea that i hoped that I would be able to get to work but after time lost interest in it.
We are the BORG..... We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE
pese
