OverUnity prize money 15825 US$ total until now
Started by hartiberlin, March 28, 2007, 07:02:02 PM
sparks
Quote from: sm0ky2 on April 25, 2008, 09:28:03 PM
a more likely scenerio:
a device comes out, and is replicated, and spreads through the world.
the energy giants collapse as a result. and the economy flourishes.
costs of products drop across the board resulting in a massive economic deflation.
cost of transportation, cost of goods, cost of shipping, ect.
everyone will have more expendible income, and therefore buy more products. and everyone benefits.
theres no economic "downside" to placing an extra gagillion dollars in the hands of the consumers.
instead of the people raping us for energy exchange.
   Nice post!    If people have some confidence in the future they will spend.  You want to stop terror tactics feed the hungry so they don't get brainwashed by some religious fanatical bullshit artists.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
The Eskimo Quinn
sorry to those who think i ignore them, but i get little time betwee work, the wheel, the website and the mail, it's 3 am here now.
the experimant with the magnets is not accurate to what i said, he used two equal magnets, i used a small and very large one, try this the get two magnets the same and a container tape one magnet inside and fill with non magnetic material and use the small against it on the outside to pull until the field breaks, keep adding weight until this happens,..........now simply turn the magnet around and it will hit the container befor it moves it, the repulsion field is not as strong. You will also note i did say the field "are equal" which is why the movement test on the paper works like it does, but that does not show the break point or strength of the fields, merely that they are there.
As to Oak, well done. So i will at this point give you a main commponent from the download.
remember i am rebuilding a previous wheel, if you simply want to build the wheel for yourself to see if it works, it should take around a day tops. if you use the quick way (which would not be "re-building" if i were to do it)
Just make one arm !! it still turns the same, one axel.. eg pedastal fan motor two match lock nuts the size of the fan shaft, an ally or stanless plate with a single hole, and fix the arm to that, you can pull the guts out of the motor if you like and leave the bearings.
you never needed a generator, any disk set forward of the arms with a circle of coils, and a stand oppsosite with a cirlce of north south magnets will produce current in the coils, so there is no concern for frictio, from power generation, there never was.
I have to do it this way because it is replication of one that worked, to do the easy thing is just someone giving instructions for something that may work, and the reason the easy way will not be on the site.
As to the low friction remarks of the gold scales, 3 kg is above the weight of a rod, so you responded as in the example of how a newtonian would respond, saying it is low on one axel but not on the other.
it is funny they dont quote their own physics to know why this frictopn does not occur atop the axel.
it is egg physics, the reason you cant break one with your fingers end to end, and the reason arches are used to build bridges, and the reason a ball will float forever on a column of air sitting perfectly in the centre.    Because energy like all force finds the path of least resistance, and with a circle the is not one, and all weight is dispersed evenly out and also around the other side.the reason the ball does not just shoot up in the air, it is pulled down also, the friction is equal on all sides.
Back to bed.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
sdanielmsev
To all:
  Isn't what you all are looking for is an electron pump? As opposed to an over unity motor, an electron pump uses all of the electrons from the air, ground, the table, eels. If the idea is to stay within the formula p=p, where do the excess electrons come from?  If I remember correctly this was Tesla's actual idea. If the idea is p<p, as output, then again where does the energy come from?
pharao
1000 EURO ??
You are kidding! Thats not even the material worth for a month development wasted!
Make 1 Million! That would be a better motivation!
powercat
