Phonon boson and Higg`s boson interactions : Energy conversion in TPU
Started by Esa Maunu, March 31, 2007, 04:06:14 AM
Esa Maunu
TPU is a system where phonon bosons are produced with a electrostriction, when pulsed HV field changes the size of the crystallic structures in a core material.
This crystallic material  changes it`s size in a HV field that leads to acoustic phonon wave emission in a core material. Phonon acoustic mode wave is a quantum analogue to vibrational sound waves, and travels with a speed of sound in a medium. We can also build up a resultant field for the acoustic mode phonons in a waveguide ( TPU core ), where wavelenght and number of waves are a prime numbers,to minimize harmonics wave production.
The core material must made of material that contains crystalline structures, or it can be in a liquid form that contains crystallic particles,for exsample E48 bluephase liquid.
There can be some benefit, if we use a bias DC electric field to have crystals orientation into same direction.
Anyway, we must know the speed of sound in a core material, when we calculate dimensions for the TPU core. The needed HV field is created with a coil, where the pulse is reflected back and forth, and gains voltage up this way.This HV pulse we can call as a "kick", when it changes the size in a crystals, or with other words, this is called as  electrostriction.
Regards,
Esa
The MEG,without subestimation,is really ease to realize because we only need
to concentrate the theories of :
Braun,Minkowski,Wiener,Kauffmann,Planck,Schroedinger
and the inventions from Joseph C. Yater and Helmut Reichelt in
1 aggregate !
Congratulations to whom which will resolve this puzzle or patch-work ,
before 2015 !
I see the actual evolution to realize the OU-motor/generator-combination,
then as next step ideas like R.Alexander and/or R.Mukherjee = semi-rotatory/static !
Lieber die fette Taube in der Hand als die klaegliche Wachtel auf dem Dach !
Sincerely
            de Lan?a
p.s.: 3,14159...-Sphere + 2,71828...-Sphere : REPRAP/VON NEUMANN/LAPLACE/
                                                               Rabbe Loew/ K.I.(A.I.)
Esa Maunu
It is interesting to see how this phonon wave theory fits with the other claimed OU / AG devices. It seems that there is a question of the phenomena, how radial E-field affects to materia that has a crystallic structure. We have enough information available about electrostriction and the behaviour of the phonon waves in a phonon maser systems to check out if this is a answer.So far this looks very promising.This can be an explanation, how Testatika and SEG works, also it is very interesting to know, what were  Nikola Teslas thoughts and goal when he build his HV coils..
Anyway, if you are interested to check out how this phonon wave phenomena fits to OU / AG devices, all research work,thoughts and conclusions are wellcome.
If this phonon phenomena is behind OU / AG devices working principles, it is relatively easy to calculate needed dimensions and make choices of the needed materials for OU / AG devices, when we know what we are looking for.
Regards,
Esa
dutchy1966
Quote from: Esa Maunu on April 01, 2007, 07:24:01 AM
It seems that there is a question of the phenomena, how radial E-field affects to materia that has a crystallic structure. Regards,
Esa
Hi Esa,
Have you got some links for us to read about that. I think you're much more ahead on this whole phonen theory then most of us here. Please get us updated a bit..... :)
Robert
Esa Maunu
Robert,
There is a lot of available info about phonon theory , i have also a lot of links, but information consists of smaller pieces on web-pages, that are important for us.
But important is that every AG / OU device has a pulsed HV  E-field and has a waveguide, made of material that has a cubic crystalline structure.
Esa
