Phonon boson and Higg`s boson interactions : Energy conversion in TPU
Started by Esa Maunu, March 31, 2007, 04:06:14 AM
Motorcoach1
Esa your a good perso : as i see the coils unon 1, the same phase wiil be different , no two colis are the same so the diffreal phaise is out of tuen, acctually this is good, if that were to happne it my dissinagrate ,poof we no more . we eed to propergate the rings in one and phase them in the magete state therefore we can be in energy current. if you look at my statement in GK's PDF migratethe LMD course to max potencia 5kz then 3 kz then 7.8 kz is potencia output . the thig is the 2 mag feilds occilate iside each other . naturatil this is the protron way we ca't alter that  we multipulat that.  tesla dule cone 157.8 1/4 wave ratio 4-1 ....the widing equles the mass of the secondary.....flat wind ..sedc.. cap..eq 4m3 of mass > df ,lmd ....mass ag not leigth ..you said that but you did not say it in your print.  ? baltioc geophicis?
shuzammy
Quote from: Motorcoach1 on April 15, 2007, 03:31:20 AM
Esa: some years ago in one of my research projects I took pure quarts granules and vaporised them in a static discharge chamber with aluminum. This enhanced the electrical property's of the material. My thought is that I take liquid silicon and make more granules 3 to 4 microns form in a toroid and bake in a microwave oven in a bisk cruseable , this may give us some information on a small unit to test with. The electrical property's are very good in holding residual electrons. The quartz came from old Ziess optics I crushed up and had some from Bell labratories this was the highest quality i could find. I also feel that this would give us a purer toriod than useing epoxys.
Wingate - as in WIN cells?
As in...  http://www.keelynet.com/interact/archive/00000694.htm   ?
Motorcoach1
Esa i have the cubes machined and things are going well .   useing 4 inch dia al disks at 110.00 vdc 17 kz  spinning by air frame 70.ooo rpm
Esa Maunu
The method how TPU converts energy from external magnetic field is done by taking a precession energy from electron, when electron is wobbling under phonon pulse. Sharp phonon pulse comes from magnetostrictive material, when control coils makes an magnetic field around composite core material, that includes both ferromagnetic and magnetostrictive particles.
This created sharp phonon pulse we can call also as a "kick", when it pushes electron precession to wobble. When electron`s precession axis direction is changed from the direction of the external magnetic field lines, electron releases a part of it`s energy in a form of photon. Photon is now a energy carrier and is able to give it`s energy to free electron, that exsist`s on collector wire. To start the tpu, there needs to be free electrons available on collector coil for photons energy, this can be done by applying a bias current to collector coil.
This technology is used also with electron tubes, when photon`s energy is transferred inside the electron tube.
Idea with a TPU is that we need only a realtively small amount of enegy in a control coil to wobble electron precession and have a energy emission in a form of photon. External magnetic field during pulses moves electron precession axis back to be in parallel direction with a magnetic field and gives it`s energy again to electron.
Also SEG works with this principle, when deformation in a  crystallic metal releases phonon pulses as rollers are moving around the stator.
http://en.wikipedia.org/wiki/Photoelectric_effect
Esa
Esa Maunu
One big benefit with the use of earth`s magnetic field in a tpu is it`s equal strenght on a small area like tpu is.
Because electron precession frequency is directly proportional to external magnetic field strenght, so this gives a very coherent photon emission, when electron precession wobbling is caused by a phonon field.  In fact, when we use composite material as a core material, mixed with magnetostrictive and ferromagnetic powder, we have thousands of small photon transducers that radiates evenly around the tpu, with the same wavelenght. This is not like a conventional dipole antenna, but like all antennas, this antenna is reciprocal also ( can both send and receive energy ).
Esa
