The Vidar-magnet motor MK2
Started by Low-Q, April 05, 2007, 12:07:17 PM
Jdo300
Hello All,
here is a torque analysis done on the first simulation file posted bu Vidar. I increased the mesh size to 0.3 for all block labels and did a block torque analysis only on the two magnets rather than a line integral around the whole rotating part. There are 72 torque points plotted, meaning the measurement was taken every five degrees around the circle for the total 360 degree rotation.
There is definitely a clear offset on the graph though I wonder if the total area still integrates to zero. I'll be happy to see how the one with three rotors works.
God Bless,
Jason O
hartiberlin
Hi Jason,
many thanks for this fantastic fast result.
Could you do some kind of script calculation
over one cycle and see if the area under the curve
in the positive range is the same area as under the zero line
in the negative range ?
If both areas are the same , the torque adds up to zero and
the motor will not run.
It could be that it really adds up to zero from your posted graph.
So we would need to tweak the design, so that it does not add up
to zero.
This could probably be done by overlapping rotors or
added flux diverser iron pieces inside the stator or rotor, so the negative torque would
not be this big in some places...
Regards, Stefan.
Jdo300
Hi Stefan,
Attached is the Excel file I use to generate the torque graphs. I input the torque data files from the simulation and it will automatically format the output for me. There are also a few tables on there that show the total positive torque points, the total negative torque points, and an average of the two. This is just an approximation of the area of the graph to show if it is more positive or negative.
It is showing that there is slightly more positive (0.7%) but since the ratio is so small, I'm willing to bet that there is an equal area around the graph. But, even with that, it is the negative spike that I am interested in. Because of what I talked about in my 90 degree rule article (www.fdp.nu/free_energy.asp?book=90), it is the spike that we want to bring in the extra energy into the system. Check out the article for more info.
Also keep in mind that the simulator cannot account for the many complex magnetic effects which could allow this to work. So I wouldn't get discourages just because it doesn't give positive results.
God Bless,
Jason O
Low-Q
I believe the simplest way to see the total torque, is to replace the two or three rotor parts with one single toroid - a ring shaped iron piece surrounding the inner permanent magnet. Then you have in theory an infinite number of degrees to calculate the average torque. If the magnetic field through the iron ring, in any way, will force the ring to rotate one way, one can probably make a working model.
Unfortunately the femm file for my last three pole motor does not longer exist. Femm has the great feature which don't ask you to save the file before closing if you have done changes to the previous saved model. So now this motor is suddenly a total different model without asking me first... ::)
Br.
Vidar
d3adp00l
what software is being used to produce the images and torque numbers.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
