Simple to make Hilden-Brand style motor
Started by Nali2001, April 13, 2007, 03:40:34 PM
wizkycho
Hi Nali2001 !
Is there something written on the motor (Current, Voltage, Power) -  seems small for washing machine ?
wiz
Nali2001
Hi Wiz,
Well I do not have these cores handy right now but these are typical washing machine motor cores rated around 300 watt at 15k rpm.
I did in the mean time found out that these cores are not all that suited since the hole for the rotor is not really truly round, but rather elliptical.
That means that the air gaps is not the same all the way, but gets gradually bigger.
i_ron, I was thinking today. What if you reversed the polarity on the coil in the last experiment. What I predict is that you can barely hold anything. But it could not work due your setup.
A better setup would be using half of what wizkycho proposed namely what you can see in the image below. I and I bet others would really appreciate this experiment!
gyulasun
Quote from: broli on October 09, 2008, 10:03:01 AM
Hi,  your picture file is zero byte?
i_ron
It shows as "o Kb" and downloads the same... so please repost and I will comment
Ron
