Simple to make Hilden-Brand style motor
Started by Nali2001, April 13, 2007, 03:40:34 PM
wizkycho
Quote from: altium on October 14, 2008, 06:49:38 PM
One simple question, gentlemans:
Do you achieve bigger mechanical output than electrical power input?????
Yes Torque -> Force -> Energy OUT increasses. Some videos are more than obvious.
Wiz
khabe
Three units series - like Trio Motor, but you have no magnetic rotor. Its like Switched Reluctance Motor (Trio version ;-)
http://www.allaboutcircuits.com/vol_2/chpt_13/4.html
It does not matter you inverted stators or rotors 120 degrees (per phase) - in reality you have 6 tooth / 2 pole cheme when speaking about 3 phase motor.
When added permanent magnets to stator core then you cot like Parallel Path Motor (again Trio version ;-)
http://peswiki.com/index.php/Directory:Joseph_Flynn's_Parallel_Path_technology,
Im not sure about advantages of this design.
TrueTrio Motor has PM rotor - is BLDC motor, to drive it with brushless controller windings need to be connected AbCaBc................
It does not matter how many tooth stator used - number of tooths always egual to number of rotor poles.
It does not matter - inner-runner or outer-runner ...
Always inverted 120 degrees per phase. When multipole motor then this angle between tooths, not full ring ;-)
Cheers,
khabe
Ergo
Quote from: wizkycho on October 16, 2008, 09:40:00 AM
@ergo - please show us some negative experiment since you say it can not be done. although You See effect is real - every experiment
shows positive results.
You are so wrong wizkycho. You just state out of the blue that every experiment shows positive results.
But it doesn't really show anything because they never compared the forced to a setup using the same
number of turns on twice the coil area. When doing this you will notice that you get the same force from
this as compared to using a permanent magnet and half the coil size.
I have performed so many test on the Hilden-Brand valve myself and it seems like there is an amplification
of force on initial tests but then you discover that you were wrong. Once you try the same size valve using twice
the coil core area and no permanent magnet you'll discover that it provides the same force at the same input.
Myself I know for 100% certainty that the magnet just replaces flux that could have been created by the coil.
Not a single test have shown otherwise.
wizkycho
Quote from: Ergo on October 16, 2008, 11:35:40 AM
The experiment Ergo , the Experiment, Your Negative Experiment is needed - Not Your certainty or mine or anyones.
Noguhty Noughty Ergo - You really don't understand Words, thats your problem.
Go talk to Koen1 and make some other plans how to disscredit free energy idea.
Does Your Goverment Pays You to be so ignorant, how much, what are the benefits, may I join ?
Wiz
wizkycho
ergo !
Besides You said it's not working too many times ? Is there any reson You are still on this topic.
Have any proposals what might work ?
Cause I have reason to post to this topic, You do not anymore.
What are You still doing here ?
Wiz
