Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
Lycanthropist
Let's take a short moment, and (please) forget EVERYTHING you've been told about testatika, just for a moment.
The Principle Experiment, who's principle was never stated, is this : rather than stuffing extra electrons into the capacitors in order to create electric potential, electrons are REMOVED from the capaitor plate(s). This is done by creating a multi-plate capacitor, each plate getting smaller in size. The smallest plate has the highest voltage per cm^3, and it ionizes the air around it. This smallest plate is separated from the capacitor "stack" and is the "wheel spokes" on the big machines, or the "plexiglass swivel" in the published experiment.
Electrons are pushed into this ionized environment by spinning the top (smallest) capacitor plates; the electrons will spin off into the air because they have separate mass and momentum from the capacitor plates; electron momentum is conserved by discarding electrons from the plates while they spin.
As the voltage dipole grows between outermost and innermost capacitor plates, current flow is available between the center plates and the environment, without destroying the original dipole that holds the voltage constant. As the load demand increases, testatika pumps more ions from it's capacitors into the air, to compensate.
I have replicated this principle experiment, with results in the range of Methernita's claims (one to two hundred volts DC of "cold" electricity, with the external load's impedance determining amperage). I will not share pictures of the replication setup (my hard work is MY hard work), but i will describe it verbally to anyone interested.
This is the basis of "cold" electricity ; instead of free electrons trying to escape from an overloaded capacitor, the capacitor is "starved" for electrons, and draws them back in from the environment when it's wires are attached to a load; this is why a motor attached to a "cold energy" source will get frosty when it stalls ... it is needing more electrons than the environment (not the capacitor!) can supply, to satisy the power-starved capacitor's "craving".
Also explained is the "fresh air" around a working testatika ; it's because of the negative ions being pumped out of the capacitors into the air around the testatika.
The magnets are not the "electron cascade" people assume they are ; they are used in a way described by Edward Leedskalnin in his "perpetual motion" circuit, to amass power (and for QED "spin" seperation of ions) ; search the net on Leedskalnin AND magnetic current for a detailed description of this.
There are more details regarding coupling the testatika to the air around it, than I have time to type out, so I will look forward future posts and forum questions / comments.
icarus
Thanx for share it.
I'm interested in. Please describe it.
Icarus
hartiberlin
@Lycanthropist
interesting ideas,
butI don?t understand, how connecting a load will drive in free electrons from
the environment ?
Where are these electrons coming in ?
Via the load ?
The load is just connected between the output terminals, so it just "shorts out"
the existing voltage there...
Please explain more.
I still think, Paul Baumann just uses excited Beta decay in
his lightly radiactive mountain crystals which
are lying inside some of the backside caps.
He just pulses onto them the High Voltage pulses of the
HV disc generator and gets bigger energy pulses back,
which he rectifies in his bigger caps.
But Lycanthropist,
maybe you did invent something like an "electrical heat pump"
and justcatch free electrons from the air and make them to use in
your device with less input ?
Many thanks in advance.
Regards, Stefan.
FriendlyBen
Hi,
I think that in all these machines like Moray radiant energy, Testatika, Tesla and else there are few principles that we can pull out to light.
There are:
1-Voltage source (at least as a starter)
2-Oscillation/r?sonance
3-Apparent differential negative resistor (http://en.wikipedia.org/wiki/Negative_resistance)
4-Ionisation/breaking the charge balance (heat pump effect analogy)
5-Collection/extraction/matching/transformation
The voltage source is present in all of them either by atmospheric (Moray, Tesla) or by electrostatic generator (Testatika)
All of them shows an oscillator and the most efficients a LC resonant circuit
To keep the oscillator going, a negative resistor element must be present. All circuit shows such an element (spark gap, ion valve) It is my own believe that Moray valve, which Moray invented and put in is radiant energy device was a kind of tunnel diode or something similar. The biggest role of a negative resistor is to counteract the damping effect of the equivalent resistive part of the LC resonant circuit on an oscillation.
Ionisation is also everywhere in those machines. Tesla made a very detailled explanation of the ionisation created by the cosmic rays in his patents number 685957 and 685958 (worth to read). Moray also claimed that the cosmic rays was the cause of the energy generation of its unit. Lycanthropist explained a bit of what he think occur in Testatika, is he right? Who knows!
Either by a transfo, a matching circuit, a transformation circuit, somehow the energy must be collected and extracted to be useful. It is a matter of fact that all these units have an interface to be utilising the energy creation.
I am convinced that no nuclear processes are involved in these machines, even if some were using bit of radioactive materials in there apparatus or part of it. Two texts lead me to this conclusion:
1-Nikola Tesla wrote a Scientific American article, "Possibilities of Electro-Static Generators" in 1934
2-"The sea of energy in which the earth float" by Moray and son, edition 4 and 5
Everyone can find these documents online with Google. In those document either Tesla or Moray's documents they are formal: There is no nuclear transformation locally!
I also believe that it should not be extremely complicated and that it is just a question of understanding what going on and gather the elements together. RF electronic technician or ham peoples should have an advance on other in this matter.
This is how I see it, putting this in application to make a working device is another world. Einstein already said something like this:
THEORY: you know it all, but nothing works. PRACTICE: all is working, but you don't know why. THEORY plus PRACTICE: nothing works and you don't know why.
FriendlyBen ;)
