Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
Implosion
Hello, i am also busy with building a testatika device. I think, they are using discs of different materials.
Because one disc must be Positive and the other negative.
That's why i am going to use a Glas disc and a Vinyl disc.
I have those two discs allready, and also the metal plates on the disc. ( chroomsteal, can be made magnetic )
I have tested with my hand ( positive ) to charge it on the back of the vinyl disc ( negative ) and if you look good on the picture, you see sparks coming to the middle. so that theory is a proof for me, that the ions are going to the middle ( to get less energie leaks )
Tell me , if i made the right choise, for using a glas and a vinyl disc.
I have not build it up yet, because i am first busy with renovate the bathroom, because we get a baby in the end of december, but I will go futher with it, when i done most work at home ( also babyroom )
Implosion
Oh i have a question,
With the wimhurst machine, the voltage is created with the brushes, but they are not on the Testatika machine. ( not the metal plates in front of the machine, those are for collecting and stearing the discs )
Where is the creation for electrons in the Testatika machine? or does it create by the two disc, rotating the opposite way? and then a distance between the disc at a few mm?
here another photo of the two discs, glued with the " lamels "
I hope you like it
sulake
How is your project doing? What about you'r renovation?
What metal do you mean by chroomsteal? Do you mean Chrome Steel = Stainless Steel ?
Where did you get all the material, I mean that those kind of steel grids are not sold every shop :)
Have you documented any test results so far?
Implosion
Hi,
Yes, its chroomsteel, and is RVS, but i can be made magnetic.
The project is now on a pauze first, because, I am gonna be a father, and am very busy with the babyroom, and renovate the bathroom. its going well, but cost alot of time.
After that i go futher with building the device.
Greetings Peter from Holland
Super
@ Lycanthropist, the best explanation i ever heard for this type of device.
Very close to beardens explanations, building a negative resistance ...
@ Peter from Holland, wow that looks very professional as far!
