Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
gauschor
Lately I charged up a double winded coil, each beginning of the wires I connected with an electrode of the Wimshurst, and both endings of the wires hanging around loosely (not connected, diameter of coil was 3 cm, 50 windings, default installation wire). As a consequence the coil charged up more and more. I accidentally touched both ends of the wire and got struck. It felt quite powerful, very much like the voltage from an electrified cattle fence (in comparison to the usual electrostatic lightnings which I remember as "stingy").
Nothing strange in here, but this double winded coil is a very good alternative to the Leyden Jars. It holds the separated charges very good. I don't know though what one can do with it. Though I tend to think that on the small Testatika the cube like arrangements on the left top/right top with the surrounding red wires looks like this type of "capacitor".
Edit: now that I think about it... if someone wants to create a little bit more distance between the 2 windings of such a "coil-cap" he could use a setup like the one shown in the bigger Testatika where (red colored cap-) wires are put around the legs of a U-shaped magnet. The distance between is quite large though...
(just monologuising here... is that a word?)
mikewatson
Regarding the Sweet VTA:-
If I remember correctly it was Tom Bearden who told me that the magnet(s) of the Sweet VTA got cool when the device was operating. Sweet told me that, Barium Ferrite magnets had to be used (strontium ferrite was useless) and they were substantially demagnetised before use to a few hundred Gauss from possible 3000 Gauss peak flux. It seems that Sweet only got one set of magnets to work.  He would not let anyone move the VTA or touch it when in operation.
Tom Bearden held the view that the VTA was sucking energy from the vacuum. It is possible that Sweet did discover something but if so no one to date has rediscovered it.  The VTA powered fuel-free car which he claimed seems to have been fiction.
The Coler Stromerzeuger  B.I.O.S 1043 "The Invention of Hans Coler Relating to an Alleged New Source of Power" gives the full reports and analysis by various professors attempting to repeat it. The problem was that Coler did not understand it either:
on page 21 of the report, (year1943):-
" The apparatus was the subject of numerous examinations by scientists and practical engineers, who in their reports almost without exception, had to admit an energy surplus or energy multiplication without being able to explain the process by present knowledge. The inventor also could not give an explanation due to lack of sufficient knowledge of the activities of the apparatus.
Due to unpleasant differences with the financiers, mostly foreigners, and the nervous breakdown of Coler because of these, the apparatus and original theories were lost".
A number experiments are detailed in this document by various Profs, and they conclude it works from the Barkhausen effect (domain jumps).
No one explains where the excess energy came from.
gauschor
I recently made a search for Testatika again, and found out that some films have been put on youtube which I previously haven't seen (but are from the interview which has been texted on some pages)
http://www.youtube.com/watch?v=ckWMc2l5urs&NR=1&feature=endscreen
hartiberlin
Regarding from what I have read about the VTA and Sweet´s  process to use high pulses to modify his Barium Ferrite magnets,
it seems, he just created very light moveable magnetic bubbles in the magnet material which
moved when some x-y coils were applied and with the z-coil he used the induction to generated the power.
As the x-y and z axis are all 90 degrees apart, the flow of output current did not drag down the exciter coils
on the x and y axis.
So it was a cool device to violate the Lenz law.
Also I met a guy on a German free energy conference some years ago,
who claimed to have used simular high voltage pulses with superimposed 50 Hz AC to build
some strange pole modulated permanent magnets.
When he used these magnets which seemed to have got a spiral magnet pattern on the outside,
on a ceramic nitrogen cooled superconductor lifting up these magnets,
these magnets began to spin themselves in the air due to these strange spiral fields they posseded.
So in my opinion the VTA was for real, but you had to have the exact good barium ferrite material to
make the right magnetic bubbles...
Maybe one should look into the manufacturing of the early magnet bubbles storage units for
computer memories, who also used this effect of moving magnetic bubbles when coils applied magnet fields...!
Regarding the Testatika:
Yes, The PR man Mr. Bosshard, who has not much knowledge of the technical side of the device and is more into
spiritual goals and bible stuff told me, that the key to the Testatika is in the crystals.
So I still think, Baumann has used electrets to generate the high voltage DC and pulsed this
high voltage on special mountain crystals containing pottassium K40 or other radioactive beta decay material
and this way charged up his Leyden jars to generate all this power.
Really just with electrostatics and electrets alone you would not get this high power output... !
Maybe just get a rotating disc,
but not 3 to 10 KWatts of output ! This can only be got from high voltage pulses excited radioactive decay processes  !
I think this is also why they did not develop this further and they told us, that
it is dangerous, probably because the radiation was getting to high in the near surrounding.
It would be good, if somebody would talk again to Mr. Cathomen from the Methernitha Community,
cause he seems to be the one, who has helped Baumann to build all the units and he would
probably know most of the secrets how to build a Testatika.
But then you have to bypass Mr. Bosshard, who does not want anybody to get in contact with the members...
When I was about 3 years ago in Linden, I just was making a walk around near the community area, but nobody wanted
to speak with me and Mr. Bosshard, whom I called then, also said, that they don´t want any further people come to
see the Testatika and that since Baumann has died all work had stopped... which seemed to me an excuse to drive me away...
Regards, Stefan.
hartiberlin
BTW, somebody asked me about my 1989 visit to Methernitha:
Well, yes it was some kind of a cult... I would say...but not a bad one..!
I was handed a medal as a member and was photographed with it in a strange holy room , something like a shrine.., and I should wear this medal all the time
as a new member... but I only stayed there for 3 days.
I thought about moving to Linden at this time, but they lived there too much isolated for a city boy like me
who was used to the Internet and all computer stuff...
The spiritual goals I liked, but you live there almost in
quietness, cause nobody speaks to each other during meal time...
So I had not much contact during this time to other people than Mr. Bosshard....
Just a quick hello to some other members but not much talks...
I wonder, how they interact which each other, maybe they have regular meetings, I just don´t know...
I did not ask this unfortunately and did not find out...
In the evenings I was alone in my guest room.
They just showed me during the 3 days there the
metal furniture factory and some other rooms,
but the holy room where I was photographed with the medal
was full of very big crystals like 10 Kg mountain stones which were cut and sawed open and showing these Juwels inside...
That was the time when Mr. Bosshard said to me, the secrets of the Testatika was in the crystals.
BTW, I never got the photo they took of me there, but I still
have the medal here somewhere...
When I find it, maybe I will post this... but maybe they don´t want this ?? Hmm...
Regards, Stefan.
