Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
Motorcoach1
Nice job Peter , I feel you choise the right matierials on the dics. I was looking over Steves web site and been studing it very closely. could we post a list of all the sites covering this machine in the first part of the thread and keep it up dated ? and start a list and merge steves tread with thid one seeing we'll be working in the same machine. Mike
Implosion
Sulake, you asked where I got the materials from, well, I work in a Perforating Fabric of metal. so better it can not be ;)
I have now made first the aluminium tubes for the long tubes. which I think, they are the energy collectors from the air.
In the meanwhile I was busy with the bathroom ( babyroom is finished ) I bought also more materials for building it up. So sometimes I go futher with it, but more with the bathroom.
I can get all perforating materials ( mesh, aluminium, rvs, chroomsteel, copper, and last time we were perforating tutanium what is very very expensive.
I will make several different brushes ( antenne keys ) some of mesh, some of aluminium, and also dual brushes, but I have to test it, what is the best.
Ok, I have to go to my work now.
Here is where I work:
http://www.perfox.com
its in europe, in holland.
Greetings Peter
Motorcoach1
@ Pete-Ã,  nice plant you work at. Must be nice to be able to have the use of the tooling. I work in a glass / plasticÃ,  fabrication plant , plant engineer , hands on , so i get to fab a lot of different things. am doing some tests on silver mirror frenzies to see if that works , very thin coating , so there are no edges.Ã,  Ã,  Ã,  good luck with the bath roomÃ,  and your new family member !Ã,  Ã,  MikeÃ,  PS what are you going to use as bearing hubs in the center. Is there any chance I could get a set of the frenzies (metal plates) like you have and how much?
Implosion
Quote from: Motorcoach1 on November 27, 2007, 01:24:39 PM
@ Pete-  nice plant you work at. Must be nice to be able to have the use of the tooling. I work in a glass / plastic  fabrication plant , plant engineer , hands on , so i get to fab a lot of different things. am doing some tests on silver mirror frenzies to see if that works , very thin coating , so there are no edges.      good luck with the bath room  and your new family member !    Mike  PS what are you going to use as bearing hubs in the center. Is there any chance I could get a set of the frenzies (metal plates) like you have and how much?
Thx Mike ( with the goodluck and new family member )
Oh that is nice working with plastics, I need some more stuff. hehe.
But i have an adres for my plastic manufacturing. not so expensive and 25 km from home.
For the bearing, I use 2 bearings for each disc. so totall 4 bearings.
I do it different then the original testatika and people who want to copy it, because there are several theories for letting the discs rotating automatic. some people say, that its rotating by the brushes ( pushing and attraccing ) and some say, by the horseshoe magnets on the floor. and some people say that there are also steel plates on the inside of the both disc's , only more distance between the plates then in front of the discs.
I think it also rotates by another small metal disc, its very close to one of the long tubes.
So I do all of these tests ( have to test first offcourse ) and when its not rotating automatic, I have another idea from my self, but then i have to add something on the ax ( the steel pin, dont know what its called in english. lol )
It a kind of Implosion technick, and there is then no lost of power. it increases. Its about voltage leaking, and i pick the leaking up again, and put it in a circle so the power is going back to the beginning.
I have allready made the aluminium tubes. ( ion antennes for the surrounding air ) aluminium is an ion-reflector ( have heard the in the docu " how ufo's fly " its on google video.
and I have made some metal brushes. different types, and I go combine it either, double layed brushes with an isolator between it. so then you get a positive charge on one side, and on the other side a negative charge, so then its easier to collect the ions from the disc. but just theories of me. have to experiment it offcourse first.
Ok here some new pictures:
Implosion
Oh Mike, about getting the perforating sheets, it was also very hard for me, because my machine could not perforate them, but another machine ( where i dont have the knowledge off ) has made them, and one off my work has made them for me. and also sneaky in the nightshift.
I have ordered the chroomsteel plates by my self, two of 2000x1000x0.5 mm. and that costed me allready 110 euro's.  and they it costed about time about 8 houres. so will be hard to make them again. i have about 96 lamels per disc, so total about 192 lamels.
But maybe you can try to email our company and ask what it cost. I have a design of it in autocad.
I have a question for you, what kind of materials do you think they use for the 2 disc's of the Testatika?
I have seen the interview from baumann, but he lies sometimes about the testatika. My understanding of the german language is enough for me)
But I have based it on the Triboelectric series. and they dont make one disc black for fun. and no one has been succesfull with copying the testatika till so far, and they all used the same material for both discs, ( plexi glass ) and they only get about 5 mv. lol, and some people nothing at all.
Peter
