Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
Motorcoach1
 @ peter - nice to hear from you. the disks only perpetuate the ion field , so the 5mv is static at this time. I got intrested in the machine when I studied weather for a vortex project and started reading about this. When Paul talked about the parts being the sky and clouds and earth that intrested me and haveing the knowledge of the weather it really made sence of how the disks worked. I'm already knolageable on the Lyten jar and the diode so thats esay for me. just need to build some. the thing you will need in the future is some Quarts from that area (swiss) or( Ural) so check with some local rock shops, I tell you why later as we get more going. I agree on the ax or pin as you call it I saw that too. and some are belt driven. but remember the disks are Ion wind makers. the only thing I thought of today on your frenzies (plates) they might be to close together, you mentioned static fireing at the tips to the center , I'm still in question about that , you need all the positive ions you can get the neg's are easy to get, I feel your fireing off the pos's but we'll see.Ã, Ã,  good luck.Ã,  sooooo girl or boy mmmmmÃ,  ;DÃ, Ã,  mikeÃ,  best reguards         opps frgot about the type of disk - plexi the black plexi has a iron compound the makes the color plus carbon lamp black , clear is just plan ole clear. in the process of the black is hit with high voltage and that turns in into a Electrct mmmmm now thats cool .......of course it destatict but still carries a charge
Implosion
Quote from: Motorcoach1 on November 27, 2007, 08:07:30 PM
@ peter - nice to hear from you. the disks only perpetuate the ion field , so the 5mv is static at this time. I got intrested in the machine when I studied weather for a vortex project and started reading about this. When Paul talked about the parts being the sky and clouds and earth that intrested me and haveing the knowledge of the weather it really made sence of how the disks worked. I'm already knolageable on the Lyten jar and the diode so thats esay for me. just need to build some. the thing you will need in the future is some Quarts from that area (swiss) or( Ural) so check with some local rock shops, I tell you why later as we get more going. I agree on the ax or pin as you call it I saw that too. and some are belt driven. but remember the disks are Ion wind makers. the only thing I thought of today on your frenzies (plates) they might be to close together, you mentioned static fireing at the tips to the center , I'm still in question about that , you need all the positive ions you can get the neg's are easy to get, I feel your fireing off the pos's but we'll see.   good luck.  sooooo girl or boy mmmmm  ;D   mike  best reguards         opps frgot about the type of disk - plexi the black plexi has a iron compound the makes the color plus carbon lamp black , clear is just plan ole clear. in the process of the black is hit with high voltage and that turns in into a Electrct mmmmm now thats cool .......of course it destatict but still carries a charge
About the frenzies, I have tested the vinyl disc, to make it static with my hands at the back of the disc. and i saw sparks at the end ( center disc ) of the lamels ( frenzies ), but if i have build it up all, and i have still sparks, then i go isolate it with an invisible paint between the lamels. ( not on the lamels ) so there are no sparks anymore, but the energy is still going to the center of the disc.
The diode is used for braking the speed of the discs in the testatika, but I will do that later. I gonna build it up, step by step, and test it step by step. also the big coils, they are for reduce the voltage to a usable voltage ( 220 to 270 volt ) I dont need that voltage, because I want to use the higher voltage for more inventions in my head.
The diode is a kind of shortcircuit. and is build by several little copper discs with an isolater in the middle of the hole.  you can see it in this picture, the copper metal discs are on the table in front, ready to build in the diode.
Futher for the horseshoe magnets and the small metal plates and the isolators between it, could be for AC/DC.
The charge is going left and right and to the left again between the horseshoe magnets. but that is just a theory from me, maybe i am wrong. so if its for ac/dc, I dont need that too. LoL.
But I am doubting if the testatika use quartz for in the tubes / leydenjars. on the single disc, they have used a primitive version of the long tubes. ( the copper spiral what is going to a small tube.)
I think, the tubes are the ion collectors from the surrounding air. There is a copper spiral through the tube, and around the spiral is a glass tube of 2 cm, around this is a aluminium tube about 7 cm, and around this is a glas tube a little bigger then aluminium tube ( 7.2 cm )
If on the spiral is a negative charge, it attracs positive ions from the surrounding air, and will charge the aluminium tube positive (  free energy ) the glass tube around the copper spiral is against shortcut ( sparks ) and the glasstube around the aluminium tube, is against dust and moist.
Only what I dont understand, if i look to pictures from the testatika, you can see, that the long tubes are build up in 3 layers. you can see it in the plasma. in the top of the tubes is less plasma. dont understand why. maybe they did it by a reason.
Well I have to go to my work now, perforating metal plats ;)
Sometimes I perforate about 500 plates in one shift, sometimes 3000 plates, depending of the perforation.
LoL. dont understand why companies uses so many plates.
Greetings Peter
Motorcoach1
Hello Peter:   I cut the glass disks today, 55cm, 6mm thick. I used solor ray bronze. I was thinking on sandblasting the frenzies or useing acid to remove the mirror surface. Let my know your thoughts on this step . hows the remodeling going  ;D thanks a bunch Mike
Implosion
Quote from: Motorcoach1 on December 06, 2007, 05:41:05 PM
Hi Mike,
I dont know if solar ray bronze glass is working, I use normal glass. Is that glass you use, coated? if its a kind of plastic, it doesnt matter, but if its metal, its not good. because then you have a metal surface on it. but you can try it. I would not sandblasting it, or maybe only one side where the coating is on, but not both sides. because you need a flat surface for static charging.
I almost build up the device. Very busy now, baby is almost coming, and I am working now in the weekend for some extra money.
Succes Mike
Peter
Steven Dufresne
I hadn't thought of this explanation for the black disk. Good one. I had read on a Keelynet page
that you can make a stronger electret by embedding it with conductive particles of some type.
Searching again turned up this: http://keelynet.com/electret.htm
-Steve
http://rimstar.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
