Source of energy, Testatika
Started by Lycanthropist, April 13, 2007, 04:01:40 PM
Motorcoach1
I do graphic art so it's easy for me. if you want I'll do a photo doc. on all the steps so you can publish them on your site. I have to make another disk to test with , I'll probably make different types in plexy glass too. I thought it came out real nice for the first one. and thanks  :D   @ pete how many days wer're counting till the new babe gets here  ;D
karl
To steven and coach,
best way to transform this collected electrons is to let them flow without capture and collect them. In this case you short out the system by using a low ohmic load (as described in my earlier post). Take a small or big glow discharge lamp. This is an ideal load in my opinion.
The rotating electrophorus is also driven by a small motor. I prefer induction motors which (ventilator, my small one is out of a microwave oven).
This motors have no backward reaction when driven with sine wave output. You achieve the sinwave by electrode shape and low ohmic constant load as in the induction motor. This motors are tuned to 50Hz. This means there is a fixed relationship between rpm and driving voltage when current is high enough.
One advantage of the electrophorus system and some other V-generators is the fact that they run under low ohmic conditions better than with a spark gap.
If you run them as a sparking generator backdrag rises.
Think about it.
In different configurations no brushes are required and no sparking areas.
karl
argona369
I think that?s close Steven.
Metal and/or bucky balls would be very
much like the metal ink layer in
the ?shock in the shower? bottle.
Possibly forming nano capacitors as well.
Its what meant in a pm I sent you a while ago
>?Ps, I think the dark disk might be like the ink.?
Cliff,
Quote from: Steven Dufresne on December 09, 2007, 01:37:33 PM
Quote from: Motorcoach1 on November 27, 2007, 08:07:30 PM
opps frgot about the type of disk - plexi the black plexi has a iron compound the makes the color plus carbon lamp black , clear is just plan ole clear. in the process of the black is hit with high voltage and that turns in into a Electrct mmmmm now thats cool .......of course it destatict but still carries a charge
I hadn't thought of this explanation for the black disk. Good one. I had read on a Keelynet page
that you can make a stronger electret by embedding it with conductive particles of some type.
Searching again turned up this: http://keelynet.com/electret.htm
-Steve
http://rimstar.org
Steven Dufresne
Quote from: Motorcoach1 on December 11, 2007, 10:06:39 PM
Mike,
Once you have some experimental data to go with it, I'd be hapy to publish the data and your disk construction technique. Just send me an email at the time.
-Steve
http://rimstar.org
He who smiles at lofty schemes, stems the tied of broken dreams. - Roger Hodgson
Motorcoach1
there is no storm just clouds  , dosen't mater how thick the metal is . it creates the storm , doesen;t mater what you make the cloud from but the storrm has to get made kinda like a hurricane just the inside vortex wall .
