Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
giantkiller
Quote from: otto on May 04, 2007, 05:51:34 AM
Hello all,
Ok, now its really enough!!!
1. Tesla patent 390721
2. Mobius strip or band
With this informations you have my biggest help since Im posting here.
Otto
I followed Otto's jumpering for the GK4 coil. This configuration is harmful!
Here is validation of an experiment to produce power in the Hi-RF and Microwave ranges:
http://www.overunity.com/index.php/topic,1872.msg21431.html#msg21431
The previously mentioned frequencies are below Radiant Energy transmissions.
http://www.overunity.com/index.php/topic,1914.msg22312.html#msg22312
http://www.overunity.com/index.php/topic,1761.msg21120.html#msg21120
The fast rise and fall time in the pulse send a very wide range of harmonics through the copper faster that it can produce a magnetic wave. Hence the discharge.
Otto said no iron and Starcruiser said caps instead of resistors. I have not tried either as of yet.
Since January 3rd I have tried other more dangerous things, i.e. stunguns. I need to cool my adventurous jets a tad.
--giantkiller. It do work!
joe dirt
Well..............................not pretty, but good enough for testing :-\
Styrofoam!  never have any when I need it.......
Gustav22
Otto has posted a drawing, which you can find here:
http://www.overunity.com/index.php/topic,1848.msg30914.html#msg30914
Otto's accompanying text goes as follows:
Quote from: otto translated into English
Do you remember SM talking about jet wings? He said we should search the web to find out how the jet wing was developed.
Since I know exactly how a jet wing looks like, I wound my control coils like that.
In the illustrations you can see an analysis of control coils, i.e. how they can look.
The top part of the image shows a control coil wound in the usual way.
The magnetic field around the coil possesses even field strength all around. Nothing unusual.
In the center you see a coil wound in an oval way. At the two "ends" the magnetic field is streched out  and the particles in these areas are accelerated.
The lowest part of the image shows HOW I DID IT.
I fixed my lamp wire to a teflon tube of 1 cm diameter.
Since you all are bright sparks it will be clear to you that such a coil is special.
With just one control coil of this kind I get an enormous acceleration of particles and a tornado and everything I need.
I used such a coil until three weeks ago and was quite satisfied with it. But now I again thought hard and I've got something even better.
As you all can see this coil looks like a small wing. If you view it from the side, I mean.
Additional drawing:
http://www.overunity.com/index.php/topic,1848.msg30921.html#msg30921
+ translation:
Hi everybody,
if some of you thought that my last drawing contains everything I know, you were wrong. The top section  of the drawing only resembles the wing of a light sports airplane.
In the center you can see a proper wing section.
In this drawing you can see HOW I wind my control coils. This way my magnetic field gets stretched out even more. Please note that the control coil starts at the "narrowest" part of the wing and also ends there. This should be the place on the wing, where max. acceleration occurs.
All I can say is: That's my way to wind these coils. Sure, nobody gives you a guarantee that my way is the right way. But as far as I know it is the best way, so far.
Otto
money for rope
chrisC
@Gustav22
Thanks for the translation of Otto's design again. Much appreciate. Does this mean that the TPU 'shape' will now be sort of wing-shaped? Also, did Otto imply this new shaped TPU is alive and 'kicking'?
Thanks
Chris
otto
Hello all,
@Chris,
look at the 2. picture, bottom drawing. This is in the moment what Im using. In this way of winding my controls I have with 1 control coil a rotational magnetic field (tornado), a lot of output power.....Im now analysing my controls to see what wire diameter, lenght.....is the best for my TPU.
Its a very f...g job because Im testing various diameters of my wires and various lenghts for my controls.
Otto
