Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
otto
Hello all,
@Rich,
just a moment.
I have only a 1 turn lamp wire for my 6" ring and another 1 turn ring for my 4" ring. Nothing more!!! If you make a 22 turn collector you will miss everything in your TPU.
On this 6" collector I have 3 control coils. You can make it with 4 control coils but then you need the Tesla patent 390721 for the rotational magnetic field. With my 3 controls I dont need the Tesla patent because with only 1 control coil I already have my "tornado".
Im analysing my control coils and in this moment I really cant say the gauge of my wires but I hope, next week Im cleverer than now.
Otto
Gustav22
The following translation is pertaining to Otto's message in German language thread
http://www.overunity.com/index.php/topic,1848.msg31122.html#msg31122
Quote from: otto translated into English
Has anyone of you asked themselves why the hight of  a 6" TPU is 1 3/4 inches??
Well anyway, inches mean nothing to me as I calculate in mm.
So 1" 3/4 = 44.59 mm!!!
That size is a 'message' for us !!!!!!!!
That can't simply be a coincidence!!!!
As I wound one of my TPUs according to my last drawing I accidentally lifted up the larger/outer ring.
That was when it happened: I could clearly see my 100 W bulb lighting up brighter!!!! Clear and obvious.
So the 44 mm hight is NOT accidental.
There is a good reason: At a certain hight the smaller and the larger rings show some coupling. Obviously some extra energy is released, as this happens. But that only happens when you hit the EXACT right spot/hight !!! Just miss it by 1 mm in hight.... and... well you just missed it. You've got to pay attention.
I for one, have prepared my collectors in a way to achieve max. coupling. The lamp wire of the small ring and the lamp wire of the large ring are fixed in a way that they are aligned. I had to construct a wooden frame, so that I can adjust the level/hight between the small and the large ring. Obviously the problem is to use plastic screws and nuts for all these adjustments.
As you see, none of the dimensions of the 6" TPU come from nowhere.
Now you know why I use 6" outer diameter, 4" inner diameter and 1" 3/4 hight.
money for rope
chrisC
@Gustav22
Thanks for translating Otto's German thread again. It's so much clearer when Otto emphasized the 44 mm height! Thanks Otto for sharing that. I sure would love to be able to find time to get my hands dirty! Much appreciate for the info. again.
Even though I can't do any replication for now, I hope the encouragement helps!
Chris
dutchy1966
@Chris C
Maybe you can share your and Otto's clearness with us...... because personally I don't see the connection yet.....
Robert
MACEDONIA CD
HI  OTTO  AKO ZNAS  CROATION  SAMO  PISI   BOLJE CE SE RAZUMEMO  OK :)
