Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Gustav22
The following translation is pertaining to Otto's message in German language thread
http://www.overunity.com/index.php/topic,1848.msg32286.html#msg32286
Quote from: otto translated into English
Hello all,
I finally ran across Erfinder?s postings. That was some days ago. Soon afterwards he deleted everything. What a pitty!!! But one of the guys of that thread has published a pdf and so we have at least saved some of Erfinder's messages.
He used to post in the tread "MEG circuits....."
Free Solid State/mechanical energy
http://www.overunity.com/index.php/topic,133.0.html
It was about a  Tesla Motor and Patent number  464 666 - Electro Magnetic Motor.
It is about a motor which shows so many similarities with the TPU that it can not be just a coincidence. Maybe you are aware that SM also studied Tesla?s patents.
First I have to mention that Erfinder converts 1 inch into 22.5mm and not to 25.4mm, as would be usual.
He states that for the Motor the ratio of Primary to Secondary should or rather must be 1:1 regarding MASS.
As I only got between 40 and 50 W with a 60 W light bulb from my TPU and was not making any progress I finally yesterday wound a new control coil:
Secondary 144?? x  22.5mm = 3.23m = 5,546 Gramms, 0.35mm wire gauge
Primary 3.17m = 5.546 Gramms, 0.5mm wire gauge
I worked out theses figures. Maybe they are wrong, as I am not a math teacher, ha,ha.
I pulsed this single control coil wit 3 freqs. My 60W bulb only lit up dimly as I only used 1 coil and just one 6?? collector, but that is not important.
However, it is important that ? when I attach another 60 W bulb in parallel, the current does not rise. My mini TPU dies NOT react to that second bulb. My analog meters remain "ice cold". The voltage, which I measure across the bulb(s) initially, goes down a few volts but after a second or so it comes back up to the same value as before. The intensity of the light is the same. The current from the rectifier is the same.
It is the first time that I get this effect.
Obviously it was my friend Pese who came up with the idea of the second bulb in parallel. He also said, that if everything would go as described there would be power in the coil. And there is power in it.
Today I will wind another 3 such control coils and find out what?s going on there.
I?m asking myself if  should reduce my collector rings according to the calculation of 22.5mm per inch. Should I calculate everything like that (22.5mm per inch)?
I guess this is worth some experiments.
I almost forgot: the similarities to the motor:
1. rotating mag field
2. 4 secondary windings
3. 6 ?? diameter
4. Aluminum ?there is also Aluminum in the TPU but people don?t know or don?t want to realize ? the heat sink of the MOSFET.
5. everything or almost everything is wired up in a similar way
There would be lots more, and that?s without going into the working principle of the TPU.
money for rope
chrisC
@Gustav22 & Otto:
Thanks again for the long translation. Yes, i also believe Erfinder was trying to make us understand Tesla's patent principles. At some point when all the clues come together with respect to vortex & magnetic resonance, i think we will see the pieces fall in place. Otto, I think you're on the right path but I'm not sure if you can count the aluminium in the Mosfet as sufficient in quantity or in position to create paramagnetic qualities to aid the magnetic field effects?
Looking forward to your new coil windings and turns!
Chris
otto
Hello all,
@Chris,
I dont know if you saw the video with a 15" TPU. There is a laaaarge heatsink or 2? This heatsink(s) are or is made from aluminium. And not to forget, this heatsink is oval in form to NOT to disturb, to say so,  the rotating tornado as I call it.
Now if we compare the motor at the other topic with our TPUs.....
I always thought as Im better in understanding and with better results I would NOT have so much to work on my TPU but I was wrong. Now I have a million ideas what to try, how to make my coils.....
A lot of work is waiting.
Otto
Bruce_TPU
Thank you very much for the update, Otto.
Great job!!
Please keep us informed, this way we do not have the same people repeating any mistakes,and can build off of your lessons.
Thank you for your time,
Bruce
Thaelin
    I guess I can be of a bit of help here. I have all the posts that erfinder made plus all the rest.  I just captured all of them and put it into a text file. Can share with anyone who wishes. That was one of my last posts there, save all for the future as there is something here to all this. The magnetic probability alone is staggering.
sugra
