Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Bruce_TPU
Rich,
Can you PM Otto and help him with this drawing.  I could not draw a good circuit to save my life and do not want to mess this up.
Thanks,
Bruce
MrMag
Otto,
I know you have been working on this for a long time and have put many hours into it. Thank-you for your hard work and especially for sharing!
Tim
lwh
Good luck Otto.  Don't let it overwhelm you.
Grumpy
Otto,
Is this the correct "final" drawing?
        -Frank Edwards
