Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
z_p_e
Quote from: bob.rennips on June 06, 2007, 11:41:52 PM
DELETED.
You are all obviously having fun doing what you are doing. I'll butt out of these thread and become just a lurker for a while.
Fun should absolutely be part of the journey here, but objectivity is required now and again as well. Bob and Grumpy et al have provided some apparent much needed "down to earthness", and I commend them for that.
Keep it up guys, sometimes things get polarized too far in one direction, and these "reality check" posts are a welcome sight.
Regards,
Darren
Gustav22
Translation of Otto's message
http://www.overunity.com/index.php/topic,1848.msg33919.html#msg33919
in German language thread
Gabi was contributing thoughts regarding Aluminium
Quote from: otto translated into English
Hallo Gabi,
I have got to get a move on.
In the big 15" TPU AlMn (Aluminium Manganese alloy) [not pure Aluminum] has to be used, in order to boost the extractable energy level!!!!
I was mentioning all you physics experts, because I only have my fingers to do temperature testing. It is you who please should  take up the work from this point on. I just wanted to give a hint to inquisitive researchers.
After all I only have my fingers to work with and to make tests with.
Please translate into English, as I think as many people as possible should get involved to save our poor planet.
Yes. The wires length of the control coils is veeeeery critically important. As I already said: it?s the first thing I have to optimize further.
Otto
money for rope
Bruce_TPU
Thank you Gustav22 for remembering us! :)
Please have Otto look at GK's and My questions on my last post on my thread and help us out.
Thank you much,
Bruce
devilzangel
Quote from: gn0stik on June 06, 2007, 08:09:09 PM
updated document per otto's request.
please review it otto.
Also, I was looking for that cross section cut out pic of the TPU.
if anyone has anything else that I missed please let me know.
Rich
thank you for compiling the current specifications and instructions for Otto's TPU. now people can get down to reproducing what Otto is showing.
devilzangel
devilzangel
Quote from: OttoIn the big 15" TPU AlMn (Aluminium Manganese alloy) [not pure Aluminum] has to be used, in order to boost the extractable energy level!!!!
please elaborate on how u know this. Why aluminum or AL MN alloy for that matter?
such alloys are shown to have superconductive properties.
Quote from: http://ieeexplore.ieee.org/Xplore/login.jsp?url=/iel5/77/31006/01439592.pdfThe authors present tunneling results for junctions comprising Mn doped Al films produced by sputter deposition, with Mn concentrations in the range of 0-5000 ppm. Our results for S'/I/S', S'/I/S, and N/I/S junctions demonstrate that Al-Mn alloys can serve both as superconductors with critical temperatures reduced from that of Al and as normal metals. The authors find Al-Mn in this doping range to be otherwise identical to pure Al in terms of its BCS-like tunnel characteristics (for superconductors) and its ability to produce high-quality tunnel barriers.
Quote from: http://adsabs.harvard.edu/abs/1974PhRvB..10..278KNeutron scattering studies were performed on an Al-0.5-at.%-Mn dilute alloy at T=80 ?K and T=300 ?K sample temperatures. The incoherent magnetic scattering cross section was measured using the Dubna pulsed reactor as a function of in-going neutron energy, at four scattering angles. The results show a nonzero magnetic moment on the Mn sites and a ξ~6 ? radius oppositely polarized electron cloud around these atoms.
devilzangel
