Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Grumpy
More food for thought - particle accelerators - see attached:
Also, when you initially apply voltage to a conductor, the electrons first align with the potential, then they start to slowly move and you have "current".  Like I have said many times before, stop them before they move and you just twisted them and then let them twist back - like you got them all excited and then told them no...pisses them right off!
Anyone have Eric Dollards book set?  What does he say about Tesla's RE discharges - he reproduced them...
Will pick up a DPDT relay tonight - want to try to duplicate Thompson's Induction coil charging effect that led Tesla to RE.  Thompson pulled continuous white arcs off doorknobs while the induction coil was running - damn easy to make - should at least try it.
        -Frank Edwards
Bruce_TPU
 @ Z-P-E
You asked, "Why stranded wire and not solid."
SM taught us that the electrons reside on the "surface" of the wire.  Using stranded wire gives you much more actual "surface area" than solid wire.  More surface area, more ions (electrons) for our mini particle accelerator.
@ All
My take on the "superconductor" question, is that somehow through the unique process of the three frequencies, mobius turns, etc.there is a disabling the flux of the wire the electrons move free as SM stated.  Once free, then "SR" Einsteins Special Relativity theory comes into play.  This is also the Cannon Ball story by SM.  This is the "Reason" the Electrons can speed up to the speed of light.
Now on Otto's coil, I will attempt to replicate it exactly.  BUT I still feel there are some missing components.  NOT to make it work, but to make it work more "efficiently".  I do not want to get into those now until after a replication.
Cheers,
Bruce
devilzangel
@gn0stik & Mannix .. thanks for shedding some light on the matter of using aluminum alloy. I dont know if the oxidation would contribute to the results we see in SM's videos. again, that a guess based on certain intuition .. the block in the center is still a mystery to me, if it was getting very very hot, it is probably bc it is getting in the way of the VERY fast rotation of the magfield. also, if the whole process was releasing microwaves, it would show some obvious affects on the aluminum.
here is what i think happens in the TPU in sequential order:
SM swipes a neo mag which starts the initial flow (pulse), which in effect starts the pulsers/freq. controls by some mechanism that acts like a switch (when it receives a pulse, it closes the circuit from a battery to the freq. gens, thus feeding the freq. gens) .. these frequencies build up causing a rotational pattern to form from shorts/kicks; which causes the progressive speeding of the shorts (kicks) in a rotational pattern due to increased flow-ability of the electrons due to more and more flux cancellation, this results in an even faster rotating mag field evident by the compass, hence the turbine scenario. This fast acceleration causes heat to build up due to the obvious inertial situations, as well as the kicks .. these kicks eventually form what "looks" like a fluid sine wave, which allows the bleed through of radiant energy into the  collectors.
i dont think that just removing the flux will make the electrons reach close to light speed, since one has to think of the relativistic affects on the mass of the electron.
devilzangel
Grumpy
Appears that it will take an extremely high voltage to make an electron approach light speed.  A voltage pulse would cause a short sudden increase in velocity.
Maybe we are not looking at this the right way.
        -Frank Edwards
