Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Bruce_TPU
Guys,
This is NEW TECH, old rules do not apply.  Remember SM's story about the diamond needle playing a vinyl record.  NOT IMPOSSIBLE< It just has not been done..till SM, Then Otto, and soon me and others who replicate it.
Reread SM's Posts about HOW the Electrons speed up to the speed of light.  It is the THREE FREQUENCIES that speed them along!!  ;)
But all the discussion falls short, TIME TO BUILD!
I start tonight, and I am very excited!
Cheers,
Bruce
MeggerMan
Quick exert from Wikipedia on the electron:
Electrons in an atom are bound to that atom; electrons moving freely in vacuum, space or certain media are free electrons that can be focused into an electron beam. When free electrons move, there is a net flow of charge, this flow is called an electric current. The drift velocity of electrons in metal wires is on the order of mm/hour. However, the speed at which a current at one point in a wire causes a current in other parts of the wire is typically 75% of light speed.
So electrons move through the conductor very very slowly and at higher frequencies move faster on the surface as per the "Skin effect".
If its true that we can get electrons to speed up in the copper, even just a small amount, you will end up with hugh amounts of current.
As for electrons moving at the speed of light, this would only occur when being boiled off from a red hot element, i.e. the coil in a flourescent tube or the cathode ray tube.
Whether its possible to get a few electrons moving very quickly I don't know.
Using high power valves and coils running at different frequencies reminds me of the Philadelphia Experiment where (allegedly) they tried to make a battleship invisible to radar during the war.
Incidently Bruce, what are you using for your 3 freq. generators?
Are you going to put then inside the TPU?
Rob
Bruce_TPU
@ Rob
My partner, has 4 mini function generators he had put together as kits, plus a "real" function generator and scope.  So we are in good shape there.  Sorry I do not have specifics...I will post all of that when we get to that point.
Cheers,
Bruce
Mannix
A very interesting read!
mechanically it does not quite fit....much of else is familiar in light of what Otto has shared with us as well.
Oh lady theory!... only in hindsight do we ever really adore her.
Quote from: tak22 on June 07, 2007, 11:47:42 AM
@Mannix
oxidation of copper is the key to the William N. Barbat patent:
"Applicant has deduced that Leimer's energy magnification most likely was due to low-mass electrons that were liberated and made conductive in the antenna by alpha radiation, which allowed these special electrons to be given a greater-than-normal acceleration by the received radio-broadcast photons. Applicant has further deduced that such low-mass electrons must have originated in a thin-film coating of cupric oxide (CuO) on the antenna wire. CuO is a dull-black, polycrystalline, semiconducting compound that develops in situ on copper and bronze wire in the course of annealing the wire in the presence of air. Such CuO coatings have been observed by Applicant on historical laboratory wire at the Science Museum at Oxford University, U.K., and on copper house wire of that era in the U.S., indicating that CuO coatings were commonplace. In later years, annealing has taken place under conditions that prevent most oxidation. This is followed by acid treatment to remove any remaining oxides, leaving shiny wire."
"Applicant's interpretation of Leimer's experiment is that the liberated low-mass electrons of the semiconductor-coating (copper oxidation) of
the antenna wire were not directly accelerated by the inductive photons of the radio signal, but rather were accelerated to high velocities by an oscillating electric field created in the metallic wire by the radio photons."
Much more to read and understand  here:
http://www.panacea-bocaf.org/files/patrickkelly/PatD25.pdf
Motorcoach1
If you want to age your copper wire- go to Homedepo they have copper Patins (acid ) to make things look old. it will leave the coating on the wire. the only problem i see is that the insulation will have to be delt with, on enameled wire. Old styel tuners and recive coils that were croded seem to work better after they aged a little , if you moved the tap to retune, it was customary to just clean the small area the tap was moved to.        if someone wants to try this take a round magnet about 2 inches long and glue a stick in the middle put it in the center of the ring and spin it fast. have fun ,,,,Mike
