Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
MeggerMan
Hi Bruce,
Are you driving the mosfets with a mosfet driver like the following:
http://focus.ti.com/lit/ds/symlink/ucc37324.pdf
This device will allow the mosfet to be turned hard-on/off very quickly so you get a good square pulse.
As you probably know that any curves in your output wave will introduce power loss through the mosfet.
This is of course using a none inductive load to test with like a 12V bulb.  When its coupled to the coil then I expect the shape to be curved again, but I think this would be OK.
Rob
ronotte
Hi all,
I DID IT
THANK OTTO!!!!!
Please as I'm writing full-time no discussion now...be patience for a few days.
Roberto
Bruce_TPU
@ Roberto
GO! GO! GO!
WAY TO GO!!!!!!
Congratulations To Otto and Now to Roberto for a successful Replication!!!
    :) :) :) :) :) :) :) :) ;D
@ Meggerman
Otto is absolutely correct on the oscillator comments and no, we do not have that...yet.
We tried to wind the collectors of Otto's TPU and want his confirmation that they are correct.  We still need to know it the double mobius is correct and if the wires need to be "on edge" around the core as one of his drawings depicts, or if it is flat against the core.  We will be putting together all of the components that Otto says.  As near a true replication is possible.  If Otto posted a drawing of his oscillator circuit this of couse would help...alot.
Cheers,
Bruce
otto
Hello all,
I was informed by my last guest that he sent pictures of our signals and a short comment to CERN. We are waiting for comments and reactions (if'??) from them.
Here was mentioned a particle accelerator. Yes, the TPU is a particle accelerator. And the effect was shown in the video. But this is ONLY ONE effect or to say it better one way to use the hugh energy that can deliver the TPU.
The point is: there is a frequency mix. When this frequency mix reaches the point of "success" your equipment is destroyed. So we must use a frequency AWAY from the point of "sucess".
With an alloy we are able to use the TPU far away from the critical frequency mix. This is the point.
You wonder how I know about AlMn, about everything Im wrighting.
1. I have readed Erfinders posts and grabbed what I needed (thanks Erfinder)
2. I have read Esu Manus posts and grabbed what I needed (thanks Esa Manu)
3. I worked a lot
As you see Im only a little man from a little country.
Maybe somebody knows a way to contact Tom Bearden and other "big guys"????
As I want to share, my "mission" is to contact the "big guys" so they can see whats going on.
The time for hiding this genious technology is over. I can only hope the real inventor got a reward for his work.
When I have finally my scope I want to explore just one point. We called it the "SEED".
In this point is the sinus "born". I want to understand whats going on in this point. How the sinus is created.....Yes, we saw how a sinus "eats" a kick.....everything. But the "seed" is special. Not easy to explain.
ChrisC
Why to hurry??? Everything is a long time on this forum.
Otto
Mannix
Otto,
You are one of the biggest guys here....thats for sure!
