Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Jdo300
Excellent Document Roberto and Otto!!
I have already procured all the necessary components to built this circuit and will be building and testing tonight. I will report back with pictures and video as soon as I get some results :).
God Bless,
Jason O
Bruce_TPU
Roberto and Otto,
What a magnificent job of documentation and explanation.  Your relentless work and tireless testing is shown throughout the document.
Seeing the "seed" was a glimpse on creation.  Very humbling indeed.  I stand in awe of HIM by whom all things consist.
Now it is time to build, and share with as many as possible.  I am humbled to see the "seed" of a new (to us!) power source spring forth.
May history speak well of you and all of those who have worked, some for years, others for months, to see this birth.
IT IS TIME TO GIVE OUR CHILDREN THE LIGHTNING!
Highest Regards,
Bruce
MeggerMan
Hi Otto and Roberto,
Excellent work by both of you, this is outstanding work and dedication towards documenting your research into the TPU.
I have read it from start to finish and I think it will make very useful reference material for my own experiments.
I had no idea that you were both working on this together and working day and night to get it done - outstanding!
What supprised me in the document was the high voltages achieved, sometimes over 500V.
I have been thinking about the aluminium heatsink heating up.
Maybe its induction heating by eddie currents from the various powerful magnetic fields present.
To prove this try a block of aluminium and it should heat up quicker than lots of small pieces or thin sheets of aluminium.
There was mention of a 15" and 16" TPU, is there 2 large TPUs or was it a typo?
In summary have you seen an excessive amount of output?
When Roberto said "I did it" does that mean you are no longer working together?
So Roberto has reproduced the experiments you both did together?
Sorry for all the questions.
Rob
z_p_e
I'm not breaking out the champagne yet guys.
I've read Roberto's latest document, and although it is relatively well written, there is no mention of what exactly has been achieved in terms of power production.
30W to 40W of power is being consumed by the device, but no indication of output power is given, other than a picture of a dimly lit bulb.
This road has been travelled a few times already with past false alarms, so until solid evidence of some sort of power production over and above that used to power the device is shown, my excitement remains on hold.
Regards,
Darren
Bruce_TPU
@ Z-P-E
Roberto Stated input was 36 watts and output was 100 watts.  That is pretty crystal clear to me!  Time to break open the champagne indeed!  LOL
