Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
ronotte
Hi Marco,
you are right.  Please be patience as the work done has been really big. Me & Otto have been doing our best. It's time that you help as well: please do it. You may be sure 100% we will help you so you will see it by yourself..it's the best.
We literally have had had not time, that's all. Of course me and Otto will do all possible tests. The turbine effect we have seen is REAL!!  We have seen it clearly.
So, what to say?..... do it and help us please.
Roberto & Otto
Hoppy
@ Roberto
I'm looking at your TPU V4 Magnetic clash test document, Page 14 which shows an excerpt from the IRF 7307 Application Note. This clearly shows a VCC rail of 12V. I understand that the CD4027 requires 6V. I've also checked the IRF 7307 data sheet and it does not mention 6V.
ronotte
Hi Hoppy,
you are right. I will amend the schematic. The +6V is needed on that schematic only for the CD4027. The IRF7307 does has a max VDS= 20V.
Roberto
dutchy1966
@Ronotte and Otto please read
In the best interest of everyone I would like to propose something. As everyone can already see, the two of you will get flooded with questions. Therefore I like to suggest that you take the question that you answer to a FAQ document and upload that every now and then as more questions get answered. That way you dont have to answer questions more then once and as more people are getting involved they can check the FAQ before bothering you. This will probably give you some more time to do other things.....
Second, if you have any other suggestions of how we should pass questions to you please tell us.
Hope you find this a workable suggestion.
Looking forward to your response.
Regards and thanks again,
Robert
hartiberlin
Quote from: -[marco]- on June 10, 2007, 05:21:13 AM
I Have been studying the document several times.
It's a nice documentation about test results however i did not read anything about:
* The gyroscopic effect.
* The Vibration /washboard effect.
* The up side down effect.
* The supposed Interaction with the magnetic field of the earth.
* The inertia effect/ turbine effect, especially the winding down part of it.
i did read something about the turbine effect,but not the slowly speeding up and down compass needle.
Can anybody give out additional information on the above effect's ?
Marco.
Hi Marco,
I guess this all comes only, if you use additional feedback coils.
As Roberto and Otto are not yet using feedback coils and still run it
on a power supply, this will probably come next to do a closed loop
feedback.
Probably then we might see these gyroscopic vibration effects.
