Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Bruce_TPU
Not only that, Stefan and Marco, but I think it is important to think of this as a "baby" tpu.  SM took years to develop what we see in the videos.
SM said that even if you did not hit on the proper frequency's that you would still see a "little" power.
To get from this stage to fitting SM's in mechanics, etc.  will take all of us working together.
BUT at least we have a working model to get started with!!
Cheers,
Bruce
Earl
Hi All,
anyone know the diameter of inner loop for 16" version ?
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
CTG Labs
Hi Earl,
Is it not better to replicate what has already been done without going bigger just yet?
If you cannot get it to work, you will not be able to get any help!
Regards,
Dave.
MeggerMan
Hi Roberto,
Ahh so we need to start off with the IRF840, 500V 8A MOSFET.
Which manufacturer: Vishay (formerly International Rectifier), Fairchild Semiconductor, ST Microtronics.
The reason I ask is that they seem to vary in specification.
A very hot MOSFET is every electronic designers worst nightmare but you are using the heat to warm up the heatsink to get electrons to boil off from the surface, very odd.
Here's an idea, mount the MOSFET onto a piece of double sided PCB and put the aluminium into the centre and heat with a blow torch.
The results you had with solder wire was very good too, could you use this in your device despite the temperatures?
I was reading a book today on Quantum Physics - light bed-time reading and there was a chapter on light interference. This was exploring the double slit experiment showing how light waves create an interference pattern when one source of light is passed through the two slits. The TPU has multiple magnetic sources, maybe there is an interference pattern being intersected by the inner coil.
Rob
Earl
TI_Power Management Selection Guide, 2Q 2007
http://focus.ti.com/lit/ml/slvt145e/slvt145e.pdf
for builders
page 23 has FET drivers
Regards, Earl
