Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Earl
Hi All,
I am thinking about using a glass plate with the inner and outer coils laid upon this plate.
In this case, the twin conductors would would oriented horizontally.  Maybe to prevent short circuits hold coils in place with silicone mastic from a cartridge.  Glass resists heat (hehehe if the glass plate melts, you have too many toasts in your power output toaster!) and has excellent HF characteristics.
The glass can also hold ALU heatsinks and circuitry.  The first thing to do is use a diamond disc + hand drill or diamond file to remove all sharp edges from the glass.
In this case bare thick copper wire (yellow-green insulated grounding wire in Europe - remove insulation) could used, or the copper wire could be tinned with solder on its surface, since solder appears to give more output voltage.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Earl
Quote from: CTG Labs on June 10, 2007, 08:18:16 AM
Hi Earl,
Is it not better to replicate what has already been done without going bigger just yet?
If you cannot get it to work, you will not be able to get any help!
Regards, Dave.
There is a saying "God helps those who help themselves".
Regards, Earl
giantkiller
@Nong,
Page 11 and table 2 on the page is an excellant start.
I would like to add that yes this a 'Baby tpu'. The scope shots that appear on page 11 on have been on my scope. In some parts of those waves I did not know what I was seeing until Moab and Grumpy pointed them out. By adjusting the lower frequency I could move the RE pulse up into the electrical pulse. But the circuit would not put out any power or runaway. Probably due to the iron core as pointed out in Otto's & Roberto's document. The iron did get hot but not as hot as the aluminium stated.
That is probably why I experienced hard kicks transmitted outside the coil due to the energy flying out instead of be held in.
We have seen a light lit. I have seen those scope shots in my tests. The tuning of the coil can be aided by adjusting the bottom frequency. I have seen RE pulses on my scope. I could not attain runaway. I could not light a light.
So this is the next stage of power harvesting. And these 2 gentlemen are expressing safety multiple times in the document.
So one more time, a light has been lit and the presence of runaway experienced. I sure am glad there are others that experienced strange things about the operation now. And this is no way indicative to express that I was here first. It was Otto's circuit both times. My windings, his mobius connections. Otherwise I would only have rewound spools of wire. The tpu graveyards are full of those, no? No body is immune.
@Roberto,
Just out of curiousity could you put an amp meter between the bulb and ground to see if current flows regardless of lighting it or not?
--giantkiller. Our history changes as of now.
nong
Grumpy
One can easily melt aluminum in a rapidly changing magnetic field do to the Foucault currents (eddy current) induced in the aluminum.
By the way, aluminum does not change color before it melts, unlike steel which goes through an nice range of colors.
Marinov projected his rotating field out of the coils, so it can be "manipulated" and still function - the field that is.
        -Frank Edwards
