Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
otto
Hello all,
@Hoppy
the work was done without MOSFET drivers. I have 3 oscillators connected directly to the gates of my MOSFETs. They are directly mounted on 3 heatsinks.
Yesterday while pulsing  my coils, the Alluminium was very hot and I touched the MOSFET: just warm. But the MOSFET is DIRECTLY mounted on the Aluminium. Oh, yes, everything is normal.
The sinuses in the pictures are not 100% formed. I did it and the result is known.
Nobody of you sees anything unusual. Good, no problem.
If allowed, a question to all the people who are surching for excess energy, looking and asking about the power supply measurments, asking a lot of questions about everything:
Did you try to replicate my setup, my coils???.....had you a little time for it???....
Dont answer, I will do it:     NO!!!!
Thanks, but please dont question before you built it.
Otto
otto
Hello,
as s..t happens I touched a lot of times my wires. First: the heat is like you would hold liquid iron in your hand. Second: after this you have the feeling that somebody is crashing the bone of your finger. VEEEERY "NICE".
Once, I pulsed a not so good coil just with 1 frequency and hold the end of the pulsed coil in my fingers. I knew that it was NOT danger. I wanted to know whats the danger that I can expect from a TPU. Result: veeeery hot.
Now Im really carefull.
Otto
ronotte
Hi all,
@Jason,
very, very good work please get my compliments. It's just like this! So go on and let me know soon. I'm anxious to check your tests.
@all,
I do know that's real difficult to accept it. It has been for myself as well as I'm a standard college educated guy. I do understand and respect all the opinions. Of course you all ,in a way or the other, are contributing to advance this knowledge. There are, as you have seen, key points: 'The Seed' is just one of them: IT'S REAL IT APPEARED IN FRONT OF OUR EYES. IT CAN'T BE DENIED! In our opinion is THE KEY to open 'the Gate'. If you will built the ECD you'll see it with your eyes: please dont question before you build it. Power measuremet: we are scared. At least let us have the right time to do something to assure our safety before pushing up the 'conversion' process (one time runaway it's enought).
Roberto
Hoppy
@ Otto
You say: -
"the work was done without MOSFET drivers. I have 3 oscillators connected directly to the gates of my MOSFETs. They are directly mounted on 3 heatsinks."
OK, so you did not use the configuration shown on page 29, Diagram 8 - Final ECD Setup. Could you then show us the exact circuit you used to achieve the results described in your document?
At the moment I do not understand why your heatsinks are getting so hot at the current drawn from the PSU. This may be because they are not being driven correctly or it may be because we have external influences but if we are to satisfy ourselves which of the two possibilities it is, then we need to drive the Mosfets in the same manner as you did and clearly not in the manner you show in your document.
otto
Hello all,
@Hoppy
in the picture is my future way to connect my MOSFETs. The only point is that my oscillators are far away to be good. At my crash I didnt notice that all my 3 oscillators crashed too. Not burned but the values of my used elements changed...couldnt see this without a scope.
Connect just DIRECTLY your oscillators to the gates of your MOSFETs. I hope the output voltage from your oscillators are not over 20V.
Dont worry, my MOSFETs are driven very well.
You forgot something: The MOSFETs MUST be inside thr TPU. Why??
Otto
