Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Grumpy
Otto,
Since no one else has asked:
What is the diameter of your 50-turn coil?
Do you have an inductance meter to measure the inductance of this coil?  If not, it can be calculated from the dimensions.  Another way is to use a known inductance value - using the old school method.
What is the length of the wire for the 50-turn coil?  You gave the wire diameter before, but include it as well to keep the information together.
Failed duplications call for more data - such as voltage and current readings.  Place an amp meter in there and get some data.
        -Frank Edwards
gn0stik
Renssaek,
Your collector is also twisted to reduce flux. That would have a big effect on your results. However our experiment using lamp wire did not help us achieve anything better.
Rich
Grumpy
If everyone wound their coils like a "Brooks coil":
http://home.san.rr.com/nessengr/techdata/brooks/brooks.html
Then this set of "circuit variables" will be about the same.
(One of you has an inductance meter or a known inductor to determine the actual inductance of the coil.)
With the difference in other circuit elements, a little tuning may be necessary.
This will make it easier to duplicate each other's experiments.
EDIT:
Example - using first equation in above link:
With coil thickness of .6 cm, 50 turns - the inductance is 38.2 micro-Henries
(This coil would have a mean radius of 1.5 x .6 cm = 0.9 cm)
        -Frank Edwards
gn0stik
Nothing more from Otto? Dang, I was hoping we'd get more details.
FatBird
I too built Otto's circuit & could NOT get anything to light.
I even tried 100 turns, & still nothing.
ChemTrails, ChemTrails, What's in your sky?
Google it.
