Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Bruce_TPU
mflynn44
About seven months ago, when Otto first posted this simple T.P.U. circuit, I build the circuit and tested it but didn't see anything of interest. Over the last four days I again built his circuit to his specifications, tested it, and again see nothing except what you would expect. Basically, more power is dropped across the bulb the higher the frequency and/or greater the duty cycle until about 50 KHz when my bulb starts to dim. Probably, the bulb dims because of the increasing filament inductance. I don't see any excess energy being generated. It makes no difference if the loop of wire is through the 50 turn coil or not. I'm finished with this Otto replication and will work on something more promising.
Bruce_TPU
tao
Let it be known, my below post isn't MEAN, it is just the truth...
Funny isn't it, you claim to know the secrets, yet you just re-quote SM and merely say 'just do it! then send me a working device'. You are claiming that you found the secret, lol, you only just found some of SM's words... Now you try to make it seem like you figured something out!
What don't you describe the EXACT MECHANISM OF THE OVERUNITY GAIN IN THE TPU!?!? Can you do that?
Or will you just re-quote SM again...
Another thing, you said:
"I am using 6BQ7-A TUBES for the input and phase inverter.....and so you can imagine how CRYSTAL CLEAR my HIGH FREQUENCIES are..."  (p.s.  You just thought he was talking about his stereo! LOL)
Do you ACTUALLY believe that we thought he was talking about his stereo?!? Are you serious?!?
Your intentions are well, but your aptitude for the TPU isn't.
In addition, in your first long post on the TPU, you are quoting all these quotes of SMs, but guess what? Many of those supposed SM quotes that are the basis of your theory, aren't even from SM!
I am bringing this all to light so that everyone reading this doesn't get excited over nothing...
Bruce_TPU
