Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
UncleFester
It's okay. His intentions are good. The only problem is that many have tried exactly what you are talking about with limited results.
Spark gaps require high voltage, and that has not yet been tried yet. But the multiple frequencies and fifteen different pulsing schemes, even multiple control coils on top of one another etc have been tried. None of them have yet to produce any significant output. Well, let me re-state, not any output similar to Mark's device (1000 to 1+ OU).
I'm not trying to discourage you or anyone else. It's just that it's much more complex than we all thought at first. I am still very optimistic, but the facts so far show that it's a deeper secret than no one has figured out yet.
Bruce_TPU
Motorcoach1
Just learn some electronics it's not that hard and you woun't have to talk about toy cars that don't run.
tao
So, you want to play the 'I'm not technical, so that is how I could see through SM's words'-CARD...
Well, let me ask you this!!!
You are saying that you understand the TPU based on what SM said. That must mean that you take into account EVERYTHING that SM said, right?!?!
Well, did you happen to read SM's post where he says that the MAGNETS ARE NOT NEEDED FOR THE TPU TO WORK?
Based on you saying that you READ and LISTENED to SM, why did you happen to disregard that post? SM said that the TPU had to be able to start via a magnet, to show that it truely was OU, because people didn't like seeing any batteries in his devices. And yes, SM said that in his first devices he used batteries, but only to power the control circuitry. Maybe you need to read more...
You are getting all these guy's poor hopes up with your large posts where you blatantly say that you have the answer, even though you have not made a simple coil! What a shame...
Bruce_TPU
