Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Thedane
Hi Otto,
First I would say that powering any experimental device directly from the power grid is a BAD IDEA! You're asking for trouble, especially when messing around with inductive devices.
If you're using a rectifier and a capacitor the only way you can dump power into the grid is by adding it as a DC component - and only when the AC voltage is below the DC voltage you supply (The rectifier makes sure this normally doesn't happen). This will saturate any item connected to the net, and you're likely to blow e.g. transformers if you keep it up as the DC dissapates power into the devices.
In order to supply usable power to the net you need to have the phases synchroniced, and then moving the phase a little in front of the phase from the net. This is something that requires extensive electronics, and isn't something you "just" do.
My suggestion is to use an insulated DC lab-power supply so you don't kill your self - or others who are interested in what's going on.
To measure any OU use a fully charged battery (12V car battery is great). Take some water, a suitable resistor and a thermometer. First place the resistor in the water and measure the water temperature (use room temperature destilled water). Dissapate energy until the battery voltage is dropping rapidly and measure the water temperature again. Calculate the amount of Joules supplied to the water. Charge the battery again the same way, and this time power the unit/TPU - and now the output from the unit goes to the resistor. Continue until you have the same battery voltage. Calculate the Joules, and if you end up with more than before - contragulations!  (Don't forget to let the water cool down) This is basic stuff tought in beginners physics. Meters can be tricked as they're usually mechanical devices with a slow response.
Happy experimenting - and don't forget: Electricity kills!
[Edit - Output should go to resistor, not battery  ;D]
Grumpy
Otto,
Sounds like you tapped into a torsion field of one of the earth grids.
Very impressive.  Keep it up.
(I think "pese" has info on torsion fields on his site.)
        -Frank Edwards
gn0stik
Otto, did your TPU have one big spike, followed by a slight maybe 1 or 2 ms gap, then a ringing that hovered under say 100v, but only diminished a little, to maybe 30v and hung there, until the next square wave pulse?
Grumpy, what is Pese's web site URL?
Thanks in advance.
Grumpy
Pese's site:
http://www.stormloader.com/members/pese/links.html
Might be easier to search for:
"tempic field"
"Torsion field"
"telluric currents"
Radiant energy is a torsion field phenomenon. (torsion and tempic are term for same field)
        -Frank Edwards
Sauron
Quote from: otto on April 27, 2007, 08:03:06 AM
Hello all,
Sorry, I have only a few minutes.
Yes, its possible to feed the power grid. Why not. I had a pumping at 5 - 10 Hz and my analog meters showed me a lot current and voltage. I dont see why this couldnt be possible.
We all should know that we can have in just 1 wire an AC and a DC signal...I dont know what signal I had in the moment when I feeded the power into the power lines but for sure I saw the output signals on my TPU. I saw almost a sinewave with a lot of hash.
But my oscillators worked with square waves!!!!  Comments???
Weekends Im offline so I can not respond.
No ,you cannot do this because it does not match the main frequency of the grid itself...
if you do so, you will cause permanent damage not only to your own equipment but also to that of all neightbours in the block....
all their transformers would go crazy or in the worst case explode due to the mutal inductions.
it's just stupid and by the way most fuses in homes are +\- 20 amps so you had to blow that one first with your 30A!!!!!!
Sauron.
