Cheap Wind-Farming
Started by lancaIV, April 18, 2007, 10:30:32 AM
seychelles
I AM SO HAPPY TODAY LANCA IS BACK IN FULL FORM. WELCOME BACK LANKA.
Quote from: seychelles on February 19, 2022, 11:12:17 PM
I AM SO HAPPY TODAY LANCA IS BACK IN FULL FORM. WEL( ::) L.) COME BACK LANKA.
https://www.youtube.com/watch?v=6zT8AyfsFmA  ;)
Schlafende Hunde nicht wecken ! 8)
But it is Sonn(en)/Sun-day,Ruhetag,Dom-in-go later Dom-out-go with-/out message
Vanuatu was well,Tonga was well ,Seychelles was well
wellewelle
Vanuatu actually less well,Tonga actually less well, Seychelles being well ::)
Funny Nixe re-/search findings wishing
OCWL
poste scriptum : I please for "Pardon-moi,s.v.p. !"
A translation/transformation error to correct : #13 :
  http://www.anfre.com/global-aluminium-smelters-production-costs-on-decline/
Rio Tinto Alcan has similar production costs, thanks to low cost smelters in Canada, powered also by low cost hydro power, with the Kitimat smelter having the lowest power tariff in the world (below US$ 6 /MWh), while its other Canadian smelters pay less than US$ 7 / MWh.
                               6 US$/1000 KWh up to 7 US$/1000 KWh =  0,6 US$/KWh up to 0,7 US$/KWh
correct -for arithmetical understanding , to write :
        instead :
        clearly :
     6 US$/1000 KWh up to 7 US$/1000 =           0,6 US$cent/KWh up to 0,7 US$cent/KWh
https://www.wiwo.de/technologie/green/marke-eigenbau-tueftler-entwickelt-windturbine-fuer-22-euro/13549092.html
https://www.youtube.com/watch?v=t9TrUPoevXI         $30 DIY Kilowatt Wind Turbine
This is the up to date build process for the OpenSource LowTech.org $30 Lenz2 vertical axis wind turbine.
The turbine can be made almost entirely from recycled materials with basic tools in six hours for $20-35.
It is tested at 35-40% mechanically efficient, generates 130 watts mechanical in a 30 km/h wind, 1 kilowatt at 60 km/h, and can survive 100 km/h gusts.
and an appropriate 750 RPM electric generator :
http://www.schillergy.com/pdf/schiller-energy.pdf
when 3000 RPM version weights ,active/passive material calculation, 2 Kg/KW
a "750 RPM 1 KW " version weights -linear estimation - 2 Kg = 3000 RPM
    ergo  4 Kg/1500 RPM  ergo 8 Kg/750 RPM
    8 Kg a 32 US$ ( reference alibaba PM motor/generator US$/Kg material) ~ 250 US$
    means : 250 US$ + 30 US$ windturbine = 280 US$ total
https://overunity.com/18143/colors-kapanadze-forum-fe-builds-circuits-and-comments/2340/
                                          #2347 / # 2350 (pseudo-) superconductive coil
                a. Ed Sines concept(US Navy R&D)             b. Haldar  Sabyasachi                c. Topchiashvili et al.
                                     each kind with +-  5x reduced costs, weights and sizes claims
                            Experiment/R&D : 8 Kg generator to 1,6 Kg generator - by same costs -
                                 1,6 Kg x 32 US$/Kg = 51,2 US$ per KW 750 RPM HTS coil generator
                   51,2 US$ generator + 30 US$ turbine = 81,2 US$ nominal 1 KW windturbine system
the above given numbers : 130 watts mechanical in a 30 km/h wind, 1 kilowatt at 60 km/h
        per hours speed   to per second speed
                                           130 watts                             8,33 m/sec  ,  1 kilowatt  at 16,66 m/sec
        compared thread #5 numbers,electric
Example: A wind turbine with a nominal 400 W (manufacturer's specification) generated at a wind force of approx. 20 m / sec. an output of 70 watts.
After converting the generator to combined windings, the system delivered with a wind force of 5-6 m / sec. 140 watts.
At 10-12 m / sec. were generated over 320 watts!
DIY-turbine  .... It is tested at 35-40% mechanically efficient ...
https://overunity.com/10640/more-efficient-wind-mill
https://www-buch--der--synergie-de.translate.goog/c_neu_html/c_08_08_02_savonius.htm?_x_tr_sl=de&_x_tr_tl=en&_x_t
ESPV-Tec GmbH & Co. KG in Blaubeuren-Asch  Wind-Pillar
Whether the statement "we achieve an efficiency of almost 100 percent" can really be proven, I leave it open.
A. 280 US$-81,2 US$/KW compared
"  ......  The variants for domestic use with 0.5 or 1.5 kW generator output cost around €10,000. Under suitable wind conditions, the 500 W system generates around 4,500 kWh of electricity per year, which can almost completely cover the consumption of an average family. .... "
                                  " we achieve an efficiency of almost 100 percent "
100% from ? arithmetical limit / Carnot limit (near closed chamber effect) / Betz limit ?
https://buergerenergieberatung.wordpress.com/category/windenergie/Mini Wind Kraftwerk liefert 4kWh – Wirkungsgrad nahezu 100%May 21, 2013
compared
https://barrylebost.com/the-lebost-wind-turbine
https://www.osti.gov/biblio/6531349-lebost-wind-turbine-laboratory-tests-data-analysis
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=barry+lebost&CPC=&IC=&Submit=Search
f.e.
https://worldwide.espacenet.com/publicationDetails/description?CC=US&NR=4295783A&KC=A&FT=D&ND=3&date=19811020&DB=EPODOC&locale=en_EP#
cw rotor output or ccw rotor output or cw-and-ccw-rotor output : speed change/power change effect
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=20121009&CC=US&NR=8283799B1&KC=B1#
with 250W or 400 W conventional generator
with improved generator ?
DC or AC or pulsed DC output !?
2 poles/ 1 coil  ,4 poles/2 coils , 6 poles/3 coils, ..... output
https://www.integrityresearchinstitute.org/CleanEnergy-Vesperman.pdf
page 5 from 33 pdf pages  Induction Coil Coating Increases Generator Output by One-Third ,David Yurth
mono-phase or triphase or polyphase output
What can DIY or team work/exploration reach ?
            280 US$-81,2 US$/KW / #13     1750 EUR/KW
             installation costs and 6 EUR cents/KWh generation
assumption : 27 % full-hour conversion= efficiency per annum
when the DIY energy conversion system has 8766 h x 27% nominal power efficiency :
( a. 280 US$ - b. 81,2 US$/KW  divided   1750 EUR/KW)  times 6 EUR cents/KWh ~
                                       a. <1 EUR cent per KWh   b. +-  0,25 EUR cent/KWh
                                  BEFORE estate renewable -clean energy- investment incentive !
                          27% is a good value for 30 meters + wind generator rotor hight over the year efficiency !
                 On house-tect or garden area installation we can ,by conventional simple 2/3/4 blades rotor ,calculating with 8% !
                           from average 8% to WIND PARC project 27% target to :
        Wind-Pillar
                            A. imposssible
                            B. impossible without help
                                a. periodically
                                b. permanently
                      suitable =      periodic or permanent wind current blow ,if not permanent over-force storing
a 500 W generator working over the year permanent = 8766 hours gives the 500 W as nominal output :
                               8766 hours x 0,5 KW = 4383 KWh output as yearly conversion gain
                                              http://americanwindinc.com/violating-betz-limit/
                                                          concentrated wind converter
https://patentauction.com/patent.php?nb=9374
                                               https://patentauction.com/patent.php?nb=16848
                                       https://www.youtube.com/channel/UCsvRPGBfbsP7oUHqytkREVA/videos
                                       https://www.youtube.com/watch?v=UukXtWSLnh8
                                       from rotoverter principle to 3:47+  assisted rotorshaft wind converter
        similar
                                               https://patentauction.com/patent.php?nb=9318
        like
                                                        atmospheric energie generator
                                               https://patents.google.com/patent/EP1841544A2/en
p.s. : I AM SO HAPPY TODAY LANCA IS BACK IN FULL FORM. WELCOME BACK LANKA.
        Nit paersoenlik nemme,Sychellianer ,in reellive that mins for Mi :
        Sonntag, 22     "  I AM SO HAPPY TODAY " :P
                                LANCA I (my older brother) IS BACK ( Alle Jahre wi(e)der ::)
                                IN FULL FORM (167.000 Gr. body weight ,without clothes)
                                imaginative :  https://www.youtube.com/watch?v=1M4ADcMn3dA
        Sonntag,22  eine Grosspackung Tostbrot,familiar, und 400 Gr. Brotlaib(chen) besorgt
                              Montag,"erweiterte " Mittagszeit ,so um 15.00 MEZ, alldas w-e-g-schnabuliert
                             (gebe offen zu, zwei Toastscheiben, durch mich !)
                 Lanca I in Muenchen,sonst,ansaessig, ehemals "Stadt der Bewegung",welch FARCE ! ;D
                 Ich werd "brot-loser" :P  Artista
                 Werd wohl es mit
https://image.jimcdn.com/app/cms/image/transf/dimension=396x10000:format=jpg/path/s2396f16b7ead81f0/image/i72e51762f41ea2c5/version/1634894781/image.jpg
                 PRANA versuchen muessen,das SURVIVAL
             [ Schon vorher schwandte ,monoton , es mir : Erbarme ,der Hesse ( gebuertig Frankfurt-Hoechst/Main) kommt !]
https://overunity.com/19066/building-an-ou-motorgenerator-combination/msg564554/#new  ;)
Dr. rer.nat. Nikola Tesla : Ergaenzer der "E"=mc² mit "E"=tc²     "E" oder e ,darstellend : spezifische Energie
A battery. A reed switch to complete the circuit.
A small rotor with all N magnets (any GOOD generator will have a rotor with N/S magnets)
A generator coil
A light bulb
A motor coil
Two small magnets
A stack of magnets (only because a stack is easier to hold and not let slip out of my hand. A single magnet will work just as well.)
                  Batterie durch Capacitor/Condenser/Kondensator aus-/umtauschen !? Bifiliar !?
                              Zeit-Displacement/Verschiebung     Ort-Displacement/Verschiebung
                  Verschiebung Winkel : Vector,Skalar,Tensor,Actuator
           Resonanz !? Resonanz-Katastrophe !? Point Of No Return
           Resonanz : source/transformer/-ponder Commutator-Connection/Anschluss  :+ zu + ? - zu - ? + zu - ?
                                            Avramenko ? 1 or 2 coils/Kabel -Anschluesse/Connections ?
                                       Resonanz-circuit : kinetical force to electromagnetic force
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=19210316&CC=FR&NR=514684A&KC=A#
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=6&ND=3&adjacent=true&locale=en_EP&FT=D&date=19210709&CC=FR&NR=521330A&KC=A#
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19220721&CC=FR&NR=540979A&KC=A#
Irgendwann einmal dann :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=89&ND=3&adjacent=true&locale=en_EP&FT=D&date=20140320&CC=US&NR=2014078802A1&KC=A1#
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=102&ND=3&adjacent=true&locale=en_EP&FT=D&date=20090326&CC=US&NR=2009079393A1&KC=A1#
Temperatur : physikalisch versus physiologisch
Energie :        physikalisch versus physiologisch
Masse :          physikalisch versus physiologisch
Zeit:                physikalisch versus physiologisch
Ort :                physikalisch versus physiologisch
Matematica     Fisica conventional versus specifica
        Algorithmica
        ciencia viva ,vida synthetica
