New Stagger Stator PMM Design. Review wanted before construction.
Started by nwman, April 23, 2007, 02:11:27 PM
nwman
Low-Q
Nice video, but there is two things that prevent this to rotate:
Right before the magnets are going under the stator magnet it is repelled backwards - look closely to the video. Then when the guy manually bypass this point it starts to rotate. However, the disc is also slowing down quite rapidly right after all the magnets has left the stator magnet. The answer to the guys question, about what's going to happend when the magnets are placed all around the disc, is that the disc will stand perfectly still. If it cannot run with fewer magnets, it does not run with all the magnets.
Br.
Vidar
pese
It can also rolling down long the table WITHOUT MAGNETS !
If it rolls "DOWN" . (mechanic solution from an faked tabel)
So , not each video or pic , tell you "in first way" the true !
You must also think , that some people hunting for the money.
Pese
nwman
What size do you think those neo disc magnets are in the Magnetic spinner? 3/8,1/2"? How thick?
Tim
nwman
Does anyone think the "magnetic spinner" is worth replicating? I think I could replicate it for $20 or so using a plastic lazy Susan turn table and ceramic disc magnets (which I now have a lot of) or if I had to I could buy the same kind of neos. I'm sure I'll probably run into the same problem I had with Tom's rails but I wanted to see what you all though?
Tim
