This is HOW THE TPU WORKS!!!!
Started by Bruce_TPU, April 23, 2007, 08:42:28 PM
Bruce_TPU
 :-X  "I have been asked to no longer post on my own threads.  The "thought police" win.
Dansway
Bruce,
Please post a .gif file or similar graphic format showing your idea.  No MS-Word docs please!
Thanks,
~Dan
Bruce_TPU
Bruce_TPU
Dansway,
Do you understand now how it works?
HIGH freq. pulsed in opposite directions of the same coil produce a big kick at the spark gap and into the bigger wire.  For some reason, this attracts many more electrons also.  He then uses the magnet to turn the moving electron into current.  He tells us in his clues what FREQ. to try.
bob.rennips
Thanks Bruce.
I think we need a further clarifying diagram or description of what wires are sparking. A spark needs to travel from one wire to another wire (obviously!). Not sure what wire ends you are talking about for the gap to jump across. This needs some voltage and current obtained from the ? frequency pulses ?
How are you applying the frequency pulse (2 wire connection) to the one wire at one end and then applying the frequency pulse to the other end of the same wire ? To me that's four pulsing wires that needs to be connected to only 2 ends of the one wire. And then there is also a spark gap on this wire ?
