This is HOW THE TPU WORKS!!!!
Started by Bruce_TPU, April 23, 2007, 08:42:28 PM
turbosetch
Well we have been playing around with this idea all night now and no real results. There is some sort of coupling showing on the scope with echos almost or delays of the initial freq injections but thats it..no kicks.
bob.rennips
Quote from: btentzer on April 24, 2007, 12:16:52 AM
I am sorry Bob.  I have too many threads going.
Let me explain.  The Bold Faced underlined is a Steve Mark quote, under the paragraph that starts off "Let's talk about Kick"
Say that you have a 5" circle of stranded wire.  This give you two ends.  Strip both ends.  Take a FEW STRANDS from the left end and run this to your controller.  Take a few STRANDS from the right end and run this to your controller. In between these two place a stripped LARGER STRANDED WIRE between but NOT touching.  This LARGER STRANDED wire should wrap tightly around (perpindicular) the 5" wire.  Place a PERM MAGNET facing North and South ABOVE the GAP. Fast step HIGH FREQ in the ranges mentioned in my first post, first in one direction and then in the other direction.  Where they MEET is a BIG KICK.  And then the electrons jump onto the larger wire, except many more of them.
Regards.
Ok, thanks. I understand how you are connecting up.
An issue you need to take into account is the speed at which the freq. will zip round the wire is phenominal. You will not be able to setup a circuit which can send a freq. in one end of the wire and then in the other end of the wire so that they meet on the wire - in the way that you describe. If you consider that transatlantic calls over underwater cables have no discernable delay, and that is a considerable distance, and then consdier the length of wire in the TPU, you'll see what I mean.
You could overcome the speed issue by having a bifilar wound coil. Sending the same signal into each and in theory they should induct each others signal. But then this is moving away from the thrust of your idea and back into the idea of deliberately creating a poorly designed transformer.
Not sure how you can solve the speed issue.
Bruce_TPU
tao
Let it be known, my below post isn't MEAN, it is just the truth...
Funny isn't it, you claim to know the secrets, yet you just re-quote SM and merely say 'just do it! then send me a working device'. You are claiming that you found the secret, lol, you only just found some of SM's words... Now you try to make it seem like you figured something out!
What don't you describe the EXACT MECHANISM OF THE OVERUNITY GAIN IN THE TPU!?!? Can you do that?
Or will you just re-quote SM again...
Another thing, you said:
"I am using 6BQ7-A TUBES for the input and phase inverter.....and so you can imagine how CRYSTAL CLEAR my HIGH FREQUENCIES are..."  (p.s.  You just thought he was talking about his stereo! LOL)
Do you ACTUALLY believe that we thought he was talking about his stereo?!? Are you serious?!?
Your intentions are well, but your aptitude for the TPU isn't.
In addition, in your first long post on the TPU, you are quoting all these quotes of SMs, but guess what? Many of those supposed SM quotes that are the basis of your theory, aren't even from SM!
I am bringing this all to light so that everyone reading this doesn't get excited over nothing...
turbosetch
TAO,
      Are you trying to tell simple people like me that I am not going to get free power from this new design!! WTF...I still have not slept since the release of the data. All I have managed to do so far is make my coil sing and buzz like a bumble bee.
And to think I thought this was the answer......... :'(
