This is HOW THE TPU WORKS!!!!
Started by Bruce_TPU, April 23, 2007, 08:42:28 PM
Bruce_TPU
turbosetch
I am finding that coulpling with these wires at any freq is tough. I could just brute force pulsed dc or ac here but I can't figure how you get multiple freqs on the wire. I see your posts about using tubes. I am a big time tube guy in the RF field. The problem with experimenting with tubes is the power supply can be high voltage and usually have to be built. Depending on the type of tube and application you may need several power sources just to get it going.
Another thing that puzzles me is the fact you talk about lower resistance on the larger wire yer the air gap or spark gap as you call it is the biggest resistor of them all. Its a neat idea but seems like more is missing then just the controller. Perhaps there is more to decode.
BTW some people on the boards are suspect in terms of credibilty. I have heard rumors of companys that are on the verge of the same technology planting people on these boards to spread disinformation and to bash others that are close to the secrets.
UncleFester
Have you seen anything resembling a vacuum tube in the SM videos? Nothing larger than a sugar cube is apparent in the coils he is running. Transformers and tubes and other cumbersome devices are simply distractions. Sm is not using them in the videos, so if you want power from the device you should not need to use any of those things.
Bruce_TPU
giantkiller
@butzer,
Don't waste your time. We are already here and in full force. The TPU dynamics have already been presented to qualified professionals 'OUT there' to no avail.
Steven had tube equipment available at the time so that is what he used.
I used my electric guitar and sound processor to measure the extent of the magnetic field around the GK4 when it was kicking out VHRF and microwave. Does that make me Eddy Van Halen?
Back away from the keyboard and put your head down.
--giantkiller. Can you spell audio engineer?
