This is HOW THE TPU WORKS!!!!
Started by Bruce_TPU, April 23, 2007, 08:42:28 PM
Bruce_TPU
bob.rennips
Quote from: btentzer on April 23, 2007, 11:52:40 PM
Bob,
Please read my FIRST post.  I have Bold faced and underlined the answer to your question, under "spark gap".  There is no actual "SPARK", just a gap.  I call is a spark gap to help others understand.
Regards,
Bruce
"Just Experiment!"
I have obviously read you first post. Spark gap means gap across which a spark travels (whether visible to the eye or not) - if you don't mean this - don't use the term.
Sorry. Your bold face doesn't answer my questions. Much of what you attribute to Steven Marks is actually guessing by Mannix. The parable is pure Mannix who was guessing how the TPU works - it is not Steven Marks. You've mixed the two together. In fact what you highlight in bold is Mannix, I believe.
If you want people to build this you need to explain better with a better diagram what wires you believe are attached to where. You can't inject a frequency pulse into a wire (that has some current behind it) without a two wire connection to that wire or some form of inductive transfer to that wire.
All you appear to have done is explain how Mannix believes the SM device works. And given Mannix doesn't have a working device....
So I ask again, how are these wire connected ?
regards Bob
Bruce_TPU
turbosetch
We are using 1:1 audio isolation transformers to couple with the wire. Currently using audio amplifier with signal generators for a crude controller.
