Downloadable Pic to help UNDERSTAND!
Started by Bruce_TPU, April 23, 2007, 09:44:09 PM
Bruce_TPU
You don't like my theory fine.  I thought this was a forum of Ideas, but I guess not, unless they conform to "the group" idea.
Motorcoach1
Thank You but i dion't have word pad we use PDF formats here so as everyone can download them.... Acrobat reader PDF format
TheOne
its not even a document, it's better you use a gif / png / jpeg for this kind of image!
Dansway
please please....not MS-Word Docs!
Use the paint program and post a gif for something!
Thanks!
~D
Bruce_TPU
