Downloadable Pic to help UNDERSTAND!
Started by Bruce_TPU, April 23, 2007, 09:44:09 PM
d3adp00l
personally the only good thing I have been able to use a stun gun for is my 6" potato gun, 1.5" arch ignites ethanol really well. But in some seriousness, I am still not understanding a few things:
1. how is any frequency on any wire without extenal input to the system.
2. I don't see a description of the "controller" in any of the talk about three rings and spark gaps.
Shrug I just don't get it.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
turbosetch
Ok I blew up the picture posted here and have the idea now. Will be working on this now since I already have equipment for the freq. inputs.
Would you care to mention how you came up with this?? I know you said clue and all that but you must have had a little some thing extra. Maybe not. Anyway nice work, if it works.
giantkiller
Quote from: btentzer on April 23, 2007, 10:46:48 PM
The collector coils (There are THREE of them) have two ends.  The coil is run around the ring, but the ends are at the top of the ring for logistic purposes to place the magnet over them.  A few strands on both ends are the inputs for the frequency being sent in opposite directions.  A LARGER STRANDED wire is placed between, but not touching the ends of the collector and wrapped tightly around JUST ONE of the collector coils.  This is the first control wire.
One of two things will happen.  The electrons will jump onto the larger stranded wire between the collector wires or will jump straight into the coiled wire wrapped around the collector.  Experiment!!
A question: Is your spark gap and my spark gap, one in the same? A little late, I guess.
Bruce_TPU
turbosetch
sure you have seen this but look at the SM coil close up. Some thing look familar?
