Downloadable Pic to help UNDERSTAND!
Started by Bruce_TPU, April 23, 2007, 09:44:09 PM
turbosetch
Anyone able to translate this to a schematic. I am having issues undrstanding the drawing. He refers to spark gaps.
Did I miss some thing did anyone actually build this and see it working or is this a theory that needs to be tested.
Bruce_TPU
Motorcoach1
Yes it looks very promising. looks like you were in a hurry , when you remake the drawing use bold line grids and keep everything in black and white so it is printer friendly . I'm sure you have thought about the SS control devise. THANK YOU FOR TAKEING THE TIME TO THINK THIS OUT. Mike
Bruce_TPU
giantkiller
Quote from: btentzer on April 23, 2007, 10:24:19 PM
THIS IS NOT a Schematic.  The coils are important, but the controller is the key.  We must walk before we run.  Make 1 coil about 5" in diameter of stranded wire.  Take a FEW strands at each end, pulse HIGH FREQ into it, offset, first in one direction and then the other.  THE Spark Gap is also the location of the freq. inputs. HAVE a BIGGER STRANDED wire in between the two, and wrapped TIGHTLY around the 5" coil.  Place a PERM. Magnet Just ABOVE the spark gap, facing N_S.  (not touching, I don't think)  Take a voltage measurement, and then we can go from there.
Like Steve said once you UNDERSTAND, the rest is wiring.  Someone better than I will need to come up with the SCHEMATIC of the controller and we can all work on the wiring of the completed coil.  But this will work!!!  And is a place to begin in the right direction!!
I have been the only one that incorporated real stun guns in my tpu circuit. Do you mean that I was that damn close? And did you know that there is an adjustable pc board based micro spark gap inside the stungun casing itself? This cuts down on the number of diode-cap stages for build up. oohweee! Radiant energy on the hip! I am a stungun slinger.
Fire 'em if ya got 'em.
--giantkiller. 8)
p.s. But safety first! No dogs, kids or birds! Be safe! Ok, call the significant other over for the test.
