EXACT MECHANISM OF THE OVERUNITY GAIN IN THE TPU
Started by Bruce_TPU, April 24, 2007, 08:50:25 PM
Bruce_TPU
I have been told to no longer write in my own threads, so I have removed all the relevent posts that did not conform to their ideas.
Sorry.  Only post an idea here if "the group" agrees.  The "theory" police.
Regards.
tao
So, you want to play the 'I'm not technical, so that is how I could see through SM's words'-CARD...
Well, let me ask you this!!!
You are saying that you understand the TPU based on what SM said. That must mean that you take into account EVERYTHING that SM said, right?!?!
Well, did you happen to read SM's post where he says that the MAGNETS ARE NOT NEEDED FOR THE TPU TO WORK?
Based on you saying that you READ and LISTENED to SM, why did you happen to disregard that post? SM said that the TPU had to be able to start via a magnet, to show that it truely was OU, because people didn't like seeing any batteries in his devices. And yes, SM said that in his first devices he used batteries, but only to power the control circuitry. Maybe you need to read more...
You are getting all these guy's poor hopes up with your large posts where you blatantly say that you have the answer, even though you have not made a simple coil! What a shame...
Bruce_TPU
tao
"The people of this forum are not mindless robots, but are very bright.  You say "poor guys" as if they can not think for themselves. "
Man, are you trying to flip this on me or what? Your actually trying to incinuate that I think the people here are robots??? Are you mad? Now you are offending me!
It's not going to work buddy. I am looking out for all the guys here.
I was here since day one, the people of this forum know this. I said 'poor guys' because there are many that are NEW to this forum and NEW to the TPU, and they come here seeing you say "LOOK EVERYONE, HERE IS THE ANSWER!!!", when all that you are really doing is reposting SM's words with some words capitalized to show meaning.
I am NOT targeting you, I am merely trying to show that you aren't really showing ANY answer at all, you are just resposting SM's words and claiming that 'we missed something.'
And what info did you give out? "Instead of keeping all of this info to myself, I chose to share it. " You just reposted SM's words.
This is over now, you obviously don't know how to discuss or debate logically, you have not addressed even one of my questions that clearly show you are in the wrong here. So, go ahead and flip it on me again and make me look like the bad guy.
I was trying to be nice to you when I said "Your intentions are well, but your aptitude for the TPU isn't."
The primary reason I posted that first reply to you was that you blasted your long post across at least 4 threads, claiming you HAD THE ANSWER, when all you did was repost SM's words. I didn't think that was right considering your post WAS FULL OF ERRORS.
And, to let you know something, I WILL be posting my final theory to the TPU, and my primary description of it won't include SM's posts, for the same reason that you can't define a word in a dictionary using that same word...
El Fin.....................................
Bruce_TPU
